All,
On the Van's carb heat muff (I know I may want to replace it in the future, but this is what i have for now), is the heat hose supposed to cover the "slit" or not? The end of the muff is open to draw air, but I wonder if the slit is also there to draw air (and should not be covered by the scat hose)?
See the slit on the attached.
http://vansaircraft.com/cgi-bin/cata...=carbheat-muff
Scott
