Old 03-12-2011, 10:51 PM
UnPossible's Avatar
UnPossible UnPossible is offline
Default Fuel Pump Cooling Shroud Question
Hey - I've been searching and it appears that removing the fuel pump to install a cooling shroud on a hung engine is no simple task.
As an alternative, I am wondering if I could;
1) cut the shroud in half
2)remove one of the bolts holding the pump on
3) attach one half of the shroud
4) reinstall the first bolt
5) remove the 2nd bolt
6) install the other half
7) reinstall the 2nd bolt
8) finally - lay up a couple of layers of fiberglass to join the two halves of the shroud back together.
I'll still have the fun of having to use a mirror to safety wire the two bolts together.
Is there any reason why this wouldn't work?
Jason
Jason Tremble
RV-7A (Flying and Sold)
RV-10 in process (@#$$%# Cabin Top & Doors)
Paid for 2020
Old 03-13-2011, 07:00 AM
N208ET N208ET is offline
Default your right
it is a pain to do. I installed one after everything else on my engine was hung as a request from my friend. Seems like it took a good part of my day. But I think you are going to have just as much time in doing it the way you described as taking the pump off and doing it right. Plus, there is quite a bit of vibration back there, the fewer pieces to rattle apart the better. Buy a sacrifical allen wrench that fits the fuel pump bolts. Cut, alter, modify it to make things easier. Seems to me that one of the fuel pump bolts wouldn't come out unless the pump was pretty much out of the accessory housing, and maybe they were both like that. Before reinstalling everything, don't forget to feel up into the accessory housing to make sure the plunger didn't slip down and will be in the way. It may be necessary to rotate the prop a little to take some pressure off the fuel pump arm. I don't know your mechanical background but if you haven't dug this deep into an engine before, you might ask a friend that has for help.
Randy
8A
Old 03-13-2011, 07:26 AM
schristo@mac.com's Avatar
schristo@mac.com schristo@mac.com is offline
Default why install it...
I wonder how typical, or necessary, the installation of a shroud over the pump really is... with a backup electrical pump available and few reported failures why install a cooling shroud initially?
A search dredged up an older poll with some good reference discussion FYI.
http://www.vansairforce.com/communit...ad.php?t=47073
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,430 on the hobbs!
ORCA Flight
Race 771
margarita!
Old 03-14-2011, 08:07 AM
kentb's Avatar
kentb kentb is offline
Default I have done temp. measurements
With just a 1 inch blast tube directed at the fuel pump there is only 2 degrees difference in temp between the sides.
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
Old 03-14-2011, 08:46 AM
DanH's Avatar
DanH DanH is offline
Ahhhh! Good stuff! Kent, please tell us more about "between the sides". Where exactly were the temperature measurements taken, and how?
Dan Horton
RV-8 SS
Barrett IO-390
Old 03-14-2011, 11:33 AM
N427EF N427EF is offline
Default Pump shroud
I believe you can effectively cool the fuel pump down a few degrees and I think installing the shroud is a worthwhile PITA.
Especially if you plan on using mogas some day....
What you can do to ease the pain is cut the ears off and use a large hose clamp to keep it in place. A couple of vertically oriented aluminum tubes pop riveted to the inside
(from the outside) will keep the distance from the pump. It's not as elegant but much less trouble than removing those Fuel pump bolts.
Do as you wish.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 600 plus hours
Running on E10 mogas
Old 03-14-2011, 01:21 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
I would file it in the round file... IMHO they do more harm than good.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 03-14-2011, 02:00 PM
Geico266's Avatar
Geico266 Geico266 is offline
Kent
Yes! I am certainly not doubting your calculations, but it seems to me it should be cooler than that side to side. Did you do a test with and without a blast tube?
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 03-15-2011, 08:46 AM
kentb's Avatar
Default My test.
My blast tube is about 2 inches away from the pump on the back/right side of it. This would be the 7 o'clock position as the pilot sets. My engine monitor can handle a 6 cylinder engine, so I bought two extra wires for the CHT ports and had a guy here at work braze the wires together to form a simple temp probe. These I have used to take many measurements under the cowl.
When I looked at the fuel pump temp I was considering weather to place a shroud around it or not.
I taped the probes, one under the blast tube and the other about 180 degrees from it. The probes were attached to just under the horizontal seam between the upper half and the lower part. I don't have the temp data with me here at work, but I recall that the difference was only a couple of degrees, so I didn't pursue the addition of the shroud. It seems to me that the metal must conduct heat around the pump very effectively.
Kent
Kent Byerley
Canby, Or
Old 03-15-2011, 10:29 AM
Default More harm?
What harm exactly are you talking about?
I am just curious.
Ernst Freitag
