Old 03-12-2011, 04:19 PM
miyu1975's Avatar
miyu1975 miyu1975 is offline
Default Oil in engine while hanging?
So I just recently hung my engine. Prior to that it was torn down a few months for inspections after long term storage and all was well. I have instaledl the dyhyrator plugs recently too. Today I pulled the dipstick and found no oil was in the engine. Shouldn't I put oil in there now for corrosion prevention? if so what kind and how much?
Ryan Allen, CFII
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 90%, fuse on order
Acro Sport 2, building
Old 03-12-2011, 04:29 PM
Mel's Avatar
Mel Mel is offline
Doesn't matter. Even if you do, it will only be in the sump.
That's not where you are concerned about corrosion.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 03-12-2011, 04:30 PM
Walt's Avatar
Walt Walt is offline
I'd go ahead and put 6 or 7 qts of your preferred break in oil in it (I like shell 100 mineral or Philipps 20W-50).
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 03-12-2011, 06:22 PM
tcrv7 tcrv7 is offline
+1 what Mel says, it's going from the filler neck to the sump.
Tom Casson
N806TC{resv}
[] tcrv7@yahoo.comCessna 120 N76137
Old 03-12-2011, 07:19 PM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Default Fill er up!
Why not fill the entire engine up with oil?
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1200+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
