O-320 full power, full rich is 13.6 gph. Add 25% safety factor and you need about 17 gph at maximum deck angle. Your measurement of 24 gph is just about what I got.
No need to tilt the airplane, just raise the full line up like this:
I used 22.5 degrees after consultation with Vans for my RV-9A. This required raising the fuel line 16" above the carburetor. You can calculate the required height by knowing the climb rate plus the angle of attack.
Don't worry, though. Your 24 gph is fine.
Vern
