Old 03-08-2011, 07:16 PM
avee8tor13 avee8tor13 is offline
Default inspection panels and covers removed for inspection?
All,
Do I have to have tunnel tops, access panels and wing tips or anything removed for the final inspection by the FAA for the Airworthiness Certificate?
Thank you
Old 03-08-2011, 07:44 PM
newtech's Avatar
newtech newtech is offline
I had to have everything opened up. Didn't remove the wing tips. My FSDO rep. really performed a thorough inspection. Actually found a tank mount bolt between two inspections that wasn't tight.
______________________
Steve Eberhart, W9JUQ
3EV - Evansville, IN
Where is Steve and the Sky Terrier?
RV-7A Slider, O-360 A1A, Catto 3 blade, 2 screen Garmin G3X Classic, GTN 650, Bionics APRS. FLYING since June 24, 2009
EAA Chapter 21
Old 03-08-2011, 07:48 PM
N941WR's Avatar
N941WR N941WR is offline
Talk to your inspector. Our FSDO guys don't even look at the plane. Mine was ready to fly when they came by. The guy didn't even have me power up the EFIS.
All he did was to make sure the paperwork was in order. It took less than 30 minutes to get my pink slip.
But then our EAA chapter has a really good relationship with the FSDO and their feeling is that if a plane gets past our Tech Inspectors, it is good to go.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 03-08-2011, 08:03 PM
flion's Avatar
flion flion is offline
Definitely ask the guy doing the inspection. I had all the covers, wingtips, etc. off and my DAR's first comment was that he was supposed to inspect the plane as ready to fly, so why are all the panels off?
EAA Technical Counselor #5357
