You need more friction on the shaft. Tighten up the hardware.
Mine has worked fantastic for the past 1,840+ flying hours. Would not want to fly the airplane without it.
Mine has lots of friction. I can fly the airplane with it if need be.
Gary
Originally Posted by Peetie the Pilot
Okay Folks!
I have the same set up in my RV-9A and I don't find it very effective at all. I can move the handle from side to side and the plane moves very little. I also find that it "creeps" back to a neutral position. What am I doing wrong and you folks are having good luck with yours? I am just about to rip it all out and put a tab out on the aileron actuated by a servo.
TIA
Peter
