Old 03-06-2011, 08:16 PM
GETST8FRM GETST8FRM is offline
Default Help: Skyview in 9A Tip-up
Purchased a flying 9A Tip-Up. I want to install a 10" Skyview & 7" Skyview. Problem is bracing behind panel are in the way. Anyone have a 9A Tip Up with Skyview or other large glass panels? How/Where did you move the bracing? Standard or tall panel? Pictures would be MOST appreciated. Thanks, Evan
Evan Tullos
Purchased & Flying RV-9A
Brandon, MS
N159RV
(601) 826-6587
Old 03-06-2011, 08:45 PM
miyu1975's Avatar
miyu1975 miyu1975 is offline
I have seen many pics of builders who cut off that portion of the panel brace that connects to the rear panel via 2 screws and fabed a 90degree angle to the end and moved the piece the left or right. This is what I plan on doing when I install my skyview. sorry no pics though.
Ryan Allen, CFII
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 90%, fuse on order
Acro Sport 2, building
Old 03-06-2011, 09:33 PM
Thanks Ryan. I apprciate your idea. Sounds easy enough. Still, If anyone has pictures, I'd love to see them.
Evan Tullos
Brandon, MS
N159RV
(601) 826-6587
Old 03-06-2011, 10:09 PM
KRviator's Avatar
KRviator KRviator is offline
G'day Evan, you might like to PM / check out russd's panel. He's installed dual Dynon's, a VP50 and couple of other doo-dads, and it looks like he's had to move the panel supports to do so. He's got photo's there showing his installation, but they're not mine, so I won't repost them here.
I plan on having dual 10" Skyviews, with a 7" and GNS430 stacked vertically in the middle...My kit's somewhere between America and Australia at the moment, so that's about as much as I can offer.
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
Old 03-07-2011, 05:52 AM
Again.....Your help is GREATLY appreciated.
Evan Tullos
Brandon, MS
N159RV
(601) 826-6587
