Originally Posted by bkc3921
I have a TMX-IO-360 Vertical w/Precision Silverhawk. Using the Vans VA-182 bracket. I cannot locate the hardware callout for the cable to servo connections..(no OP-22), and seem to be getting more confused. Couple of questions. Is the FF-702 spacer used in the Fuel Injected install?..Cables appear lined up, just wondered if it was optional. Also, is the FF704 mixture bushing used in the FI install? One more: One of the plans I have shows a steel nut on the AN3 bolt, but I have heard the OP22 calls for a castle nut/cotter pin for the FI. If someone could help me on this I would appreciate it!..Also, if anyone has an OP-22 they could e-mail (bkc3921@yahoo.com) that might also help. Thanks in advance.
I have the same setup. I installed the spacer on the mixture arm but took it off because I thought it made the mixture cable attach mechanism too close to the side of the cowling scoop.
I don't have OP-22 here at home with me but I'll try to stop at the hangar on the way to work, find it and email it. I also used the Van's control cable "kit" (it was something like $5).
Both doi, indeed, use a bolt with a castle nut and cotter pin, and a rod end bearing surrounded by larger washers.
