Old 04-09-2006, 08:42 PM
dan's Avatar
dan dan is offline
Default In search of: NASM47196
Apparently MIL-R-47196A (mil spec on rivet shop heads, etc.) has been
canceled and superseded by NASM47196. I have a copy of MIL-R-47196A that I stole from Gil Alexander (http://www.rvproject.com/MIL-R-47196A_MI.pdf) but I'm in search of a copy of the NASM47196 spec.
If anybody has a copy of NASM47196 that you are willing to share, can you
email it to me? (dan rvproject com)
Dan Checkoway RV-7
Old 04-09-2006, 09:27 PM
az_gila's Avatar
az_gila az_gila is offline
Dan ... I'll see if I can hit up one of the mechanical guys at work for a copy.... but in general, when the govt. turned these specifications over to independent standards organizations (Aerospace Industries Association of America/National Aerospace Standard, in this case), the first version was just a re-print with a new title....
That appears to be exactly the case here.. this MIL-Spec document says to just use the new title for all references...
http://assist.daps.dla.mil/quicksear...t_number=25976
The technology for the type of rivets we use hasn't advanced in quite a while.... --- since the 1940's (???)
gil in Tucson
Old 04-10-2006, 06:01 PM
az_gila's Avatar
Exclamation Found it
Dan... I got a copy of the NASM spec.
Unfortunately, it came from a spec. search company we use at work, and it also got copyrighted when it became an AIA specification... so I can't publish a copy.
However, I checked it line by line, and as I thought, it is an indentical copy, just with a different title.
The paragrah numbering in your PDF copy makes your version easier to read, and the pictures I created many years ago (1990?) are also easier to read....
So no changes in the re-numbering.....
gil in Tucson
Old 04-10-2006, 06:51 PM
dan's Avatar
dan dan is offline
Thanks Gil. I appreciate the heads-up, and I think we all owe you a beer for putting the effort into that original PDF.
Dan Checkoway RV-7
