Old 03-04-2011, 04:14 PM
ArVeeNiner's Avatar
Default How much does your windshield fiberglass flex?
I'm having a bit of trouble deciding when to stop adding fiberglass over top of the roll bar/windshield of my slider. I haven't cut the fiberglass down to it's proper overhang yet (1/4" to 1/2" beyond the windshield says the drawing). Over the top, where people tend to grab, I mixed in some milled glass and flox to strengthen it up so it's pretty stiff up there. Along the sides however, I didn't stiffen things up as much. There is a bit of flex there and I know, that's not good for the paint that will be eventually on there. When I cut the fiberglass to its proper size, the smaller moment arm will mean less flex of course.
So, my question is, just how stiff do I make this fiberglass? Does anybody's flex a little bit and has that been ok?
Kelly Johnson
San Jose, CA
RV-9A
Pink slip issued: 5/7/12
Phase I Complete: 8/18/12!
2020 donation: complete
Old 03-04-2011, 04:59 PM
Lars Lars is offline
Carbon. Just add carbon fiber Seriously, the stuff is amazing.
Lars Pedersen
Davis, CA
RV-7 Flying as of June 24, 2012
960+ hours as of June 30, 2020. Where did the time go?
Old 03-04-2011, 07:01 PM
Jeff Vaughan's Avatar
Jeff Vaughan Jeff Vaughan is offline
After watching Vans demo plane at Oshkosh crack while a person put pressure on the top of the fiberglass over the roll bar, I deceided that I would build mine really tough. I too used carbon. I think I used two layers along with 4 layers of regular glass. I may have added another layer or two of regular glass. I have no flex. Just the way I planned it. If you wish I can measure the thickness.
Jeff Vaughan
RV 12 N237VW ELSA
RV 7A N561EV Sold
West Chester Pa
2020 donation current
Old 03-05-2011, 06:09 AM
pierre smith's Avatar
Default There are aftermarket handles.....
....that you can install even with the windshield already in place. They are a natural "grab" and will hopefully prevent passengers from grabbing the fiberglass. That and give them a thorough pre-flight briefing and no-no's
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 03-16-2011, 10:50 AM
Default handle manufacturer / supplier ?
Pierre, do you know the name of a MFG or supplier for those handles. I have been searching VAF but have not found it (yet).
Old 03-16-2011, 11:30 AM
rvmills's Avatar
rvmills rvmills is offline
Glen,
I bought the handles on Aircraft Extras here. Easy install...just watch the plexi as you drill the holes in the roll bar, and watch the fit of the slider over the handles. Mine is just a bit close, and the paint on the handles shows it a little.
When I brief folks on how to climb in, I demo how, then I point out the handles, and ask them not to push or pull on anything red (my paint) or clear.
I'll check on the flex of the top and sides today for Kelly...though I got what I bought, so it may not be definitive...just one data point.
Bob
Bob Mills
RV-6 "Rocket Six" N49VM
Reno-Stead, NV (KRTS)
Old 03-16-2011, 11:33 AM
thanks Bob, I will be super vigilant with my passengers as there are no handles. :-)
Old 03-16-2011, 11:38 AM
rvmills's Avatar
Side rails, windshield support down tube and seat back top are the "integral" handles. And I tell 'em just step on the seat (a pad protects it)...but better a foot mark than a cracked canopy, eh!!
Bob
Bob Mills
Old 03-16-2011, 12:06 PM
gereed75 gereed75 is offline
Default grab handles
the aviation department at Home Depot has a great selection of U-shaped grab handles (door pulls)!! Look in the aircraft cabinet department.
My fairing is pretty robust, I think four layers of heavy glass, maybe .125" thick. probably the weakest link is the bond between glass and plexi. That is pretty fragile no matter what.
Fly on!
Gary Reed
RV-6 IO-360
WW 200 RV now an Al Hartzell for improved CG
Old 03-16-2011, 12:31 PM
ArVeeNiner's Avatar
I just cut down my glass to extend beyond the roll bar by just over an inch the other night. The drawing shows 1/2" max but I'm going to stick with an inch for now. I have to say, I really don't have any flex to speak of now. My efforts in sandwiching chopped glass between fiberglass layers seemed to have paid off.
I'll fly it around for quite a while without paint so if I need to make any mods, they should be easy. I could also add handles in the future if I need to but as of now, that looks unnecessary.
Thanks for the replies.
Kelly Johnson
San Jose, CA
RV-9A
