Old 03-04-2011, 03:38 PM
idleup idleup is offline
Default Oversized Instrument Panel...
As I lay out my panel I am learning that I could really use another inch of height, does anyone make a panel blank just like vans but an inch or so taller? I do not want an affordable panel or modular, carbon, etc., or anything like that... just simple vans style but a little larger. I know I can probably just make my own but I do not have a bending brake to make the bottom flange but if there is no other option I guess I could go that route. Any feedback would be appreciated, thanks.
P.S. This is for an RV-7A. My current panel from my kit is an F-703
Matt Johnson
RV-7A Finishing Kit
http://www.rv7a.com
Old 03-04-2011, 03:44 PM
jay.pearlman jay.pearlman is offline
Default panel extension
I added an inch to the bottom on the -6 panel. It still left enough room for legs.
Old 03-04-2011, 04:20 PM
shuttle's Avatar
shuttle shuttle is offline
Hi Matt,
I made my own and it was no big deal if you have the standard panel blank as a template. I bet you can find a bending brake somewhere nearby if you go look.
Steps are:
1) get yourself some right-size sheet ali.
2) bend the bottom flange
3) position and clamp the standard panel blank over the sheet.
4) match drill and cleco the rivet holes around the top.
5) mark out the outline
6a) remove the template and cut around the marking, or
6b) as I did, course cut first then use a router to match cut the template shape.
I cut pretty much to the same shape as the standard but if I were doing it again I would try to include the underhang below the sidedecks where the airvents go in the panel shape.
Or the simpler alternative is to call up Van's and ask the to make you a deeper panel, which I believe they are more than happy to do
Best of luck,
Steve
Steve Hutt
West Sussex, UK
RV-7 G-HUTY (not flying yet)
( Tip-UP / TMX-IO-360-M1B / Hartzell 7497-2 / 1x LSE PLASMA III / Dual AF4500's / AF-Pilot AP / 695 )
Old 03-04-2011, 04:31 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Vans makes an oversize panel blank about 2" taller than normal with the flange pre-bent. You just need to trip the top profile to the length you want it. Just call them or look on their website.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 03-04-2011, 04:46 PM
Jerry Fischer's Avatar
Jerry Fischer Jerry Fischer is offline
Default Oversize Panel
Since I went with all electrical steam guages, I added to both side of the control center section and riveted an angle across the bottom.
Jerry Fischer KW4F
VAF# 1646
USS Randolph CVS-15 V-6 Div. AT2
RV7 N364SJ Miss Sandy sold
RV1 N1583 "Mockingbird 1" SOLD
EAA volunteer SNF
HBC volunteer/co-chairman OSH
Tech counselor
Old 03-04-2011, 07:57 PM
frazitl's Avatar
frazitl frazitl is offline
Default I added 1.5"
and used a 3/4" x .0625 angle for the bottom. Cut a new blank for .0625 sheet using Vans blank as a template. Next time I might go a little thicker, say .1" or so. Then I hinged the panel underneath at the sub panel to allow the whole thing to tilt for easy access in the future. I can sit in the seats and get to all of the behind the panel wiring with relative ease.. Hope the photos below make sense...
Terry F.
RV 7A N457RV
250 hours and lovin it!
Southern Nevada EAA Chapter 1300 - www.eaa1300.org
Paid VAF 03/17
Old 03-04-2011, 08:43 PM
N941WR's Avatar
N941WR N941WR is offline
I put in an Affordable Panels panel with a recessed sub-panel for the switches and breakers. The main panel is the standard height but they do make taller ones.
The sub-panel has worked out great and I have some red electroluminescent tape above the switches.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 03-04-2011, 09:25 PM
Rick6a's Avatar
Rick6a Rick6a is offline
Originally Posted by alpinelakespilot2000 View Post
Vans makes an oversize panel blank about 2" taller than normal with the flange pre-bent.........Just call them or look on their website.
When I realized the stock instrument panel was just not large enough to accomodate my instrument desires, I ordered and installed Van's oversize instrument panel. Offering an additional 2.2" of height over the stock panel, the added surface area negated the need for a subpanel although I did add a removable subpanel to it to accomodate all the control cables. I do not find the additional size to be the slightest problem concerning ingress and egress. It can be confusing trying to find the oversize panel on "The List." Give Van's a call. They will know exactly what you need.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 03-07-2011, 09:51 AM
kentb's Avatar
kentb kentb is offline
Default Matt, I had the same issue....
I can't remember if it was 1 or 1.5 inches more that I needed. I call Vans and asked about a blank piece of AL to build a new panel with. I think that it was Scott Rising that I talked to. He told me that he would make me a new panel just like the one that came in the kit at any height that I wanted.
I think that the cost was $65, but that was 7 years ago.
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
Old 03-07-2011, 10:36 AM
JoeBlank's Avatar
JoeBlank JoeBlank is offline
Default F-6103 OVSZ
For a taller panel in the RV-6/7/9, order the:
F-6103 OVSZ OVERSIZE PANEL 13"X42"
It runs about $60 or so, and is rectangular in shape so you will have to match the top contour with your existing panel and cut it.
Joe Blank
RV-6
IO-320-D1A
Advanced Flight Systems
Van's Aircraft Inc. Technical Support-Retired
EAA Tech Counselor & Flight Advisor
www.westcoastravens.com
