Old 03-04-2011, 01:55 PM
RV404 RV404 is offline
Default MOGAS 0-540?
I am sure this has been talked about before, but with 7 A gallon at my local airport, Looking in to options,
has anyone used MO gas in the 260 hp Lycoming's?
Old 03-04-2011, 02:26 PM
Geico266's Avatar
Geico266 Geico266 is offline
No problem.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 03-04-2011, 03:42 PM
Kahuna's Avatar
Kahuna Kahuna is online now
The gas does not know what engine its in.
all other mogas threads and discussions apply.
Kahuna
6A, S8 ,
Gold Hill, NC25
Old 03-05-2011, 06:30 AM
pierre smith's Avatar
Default Bob.....
....The 0-540/IO-540's are essentially the same cylinders and pistons as the 0-360's....should be 8.5:1 compression as well. So you have a 360 cu. in. engine plus 2 more cylinders.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 03-05-2011, 07:37 AM
9GT's Avatar
9GT 9GT is offline
I asked the Lycoming Tech guys this question two years ago at one of their engine dis-assembly/assembly forums for my engine, a IO-540 V4A5 and was told it was fine to use it.
David C.
Howell, MI
Old 03-05-2011, 08:15 AM
frankh's Avatar
frankh frankh is offline
Default As long as
Proper proper precautions are taken to avoid vapour lock.
540's tend to get hot around the fuel pump area...which of course is he root of the vapour lock problem.
Frank
