Old 03-04-2011, 01:53 PM
Greg Arehart's Avatar
Default Brake shutoff valve
I'm in the process of putting extended axles on my 9 so that I can use 6-inch wheels when necessary. I'm thinking of putting a shutoff valve on the bottom of the brake line (at the wheel) so that I can avoid having to bleed the brakes extensively whenever I change wheels.
Has anyone ever done this? Suggestions on a valve that is light and small enough to put there? Reasons not to do this, assuming I can find a valve that fits inside the wheel pants/fairings (other than weight)?
Thanks for any input.
cheers,
greg
Greg Arehart
N 7965A
Old 03-04-2011, 02:52 PM
Tom Martin Tom Martin is offline
I had tried a different kind of "curl" on my brake line on this plane and that idea caused about three failures at the fitting. I have since gone back to a standard larger loop with no problems. However what I did discover, during those repairs, was that if you remove the breather vent from the master reservoir and replace it with a plug you can work on the bottom of the brake lines without having to bleed the system. This has to be done before you open any fittings and there must be fluid left in the master reservoir for this trick to work. After the repair, or wheel change in your case, just put the vent back in place and give it a try!
Tom Martin RV1 pilot 4.6hours!
CPL & IFR rated
EVO F1 Rocket 1000 hours,
2010 SARL Rocket 100 race, average speed of 238.6 knots/274.6mph
RV4, RV7, RV10, two HRIIs and five F1 Rockets
RV14 Tail dragger
Fairlea Field
St.Thomas, Ontario Canada, CYQS
fairleafield@gmail.com
Old 03-04-2011, 03:03 PM
rocketbob's Avatar
Why not just use 380x15x5 tires, which are a 6" tire on a 5" rim?
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 03-04-2011, 03:07 PM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
cheers,
greg
Are you also changing the brake calipers???
If you are not changing the calipers, only removing them to facilitate the wheel change, then use a piece of hose to allow the caliper to swing out of the way, without having to disconnect it.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 03-04-2011, 03:09 PM
N941WR's Avatar
N941WR N941WR is offline
Greg,
You don't need it. During my engine replacement, I never once opened up the brake lines. They just unbolt and you can move them around as needed. That is with the SS lines we exchanged emails about.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 03-04-2011, 04:48 PM
Good suggestions all. I will be using flexible lines, and the brake reservoir trick sounds perfect. Mike, I don't know whether I will need to change brake calipers yet until I buy some wheels. Would be ideal if I don't need to even break the line! Bob, I just wanted some more tire options for flying into some rough strips in northern BC/Yukon. Might not need huge tires, but I'll see this summer.
greg
Greg Arehart
N 7965A
Old 03-04-2011, 04:54 PM
scsmith scsmith is offline
Default I second that!
The 380 x 15 x 5 (also 15/600 x 5) tires are GREAT! fits stock axle, hub, brake, wheel pants, but gives almost all the benefit of a 600 x 6.
I did mount my wheel pants 1/2" higher than stock to get extra ground clearance as well.
I strongly recommend a flex hose at the brake connection rather than a hard tubing loop. Sounds like Greg's doing that.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 03-04-2011, 08:32 PM
Yes, I'm a firm believer in the flexible brake line rather than the aluminum tube. Last thing I need is brake failure (well, I guess engine failure was not fun either).
So, I'm trying to figure out tires - the designations are all a mystery to me - any links or suggestions on where to find the specs on these? I've found a few things that are close on the Desser site, but none really tell me that they will fit on 5" rims etc. And how much fiddling does it take to fit them inside the standard wheel pants? Here's the tires I think you are describing:
http://www.desser.com/store/products...RAFT-TIRE.html
Certainly would be cheaper than a second set of wheels....
greg
Greg Arehart
N 7965A
Old 03-04-2011, 10:39 PM
LarryT LarryT is offline
Default How to open brake lines
By depressing the master cylinder slightly, the seal will travel past the compensating port (hole where fluid enters m/c from reservoir). Then the far end can be opened without losing fluid (similar to pulling a soda straw out of a glass with your finger over the top of the straw).
This is only for FYI. Personally I would use braided SS teflon hose because aircraft brakes are more of a PITA to bleed than cars. The flex hoses on my cars enable me to change disc brake pads without opening the hydraulic system at all. Just push the pistons back into the calipers with a big C-clamp.
LarryT
Old 03-04-2011, 11:27 PM
You can buy quick-disconnect fittings that are used on motorcycles for racing. They are designed for this purpose and I have never seen a failure. Motogp brakes see far worse conditions than the RV any day, if they can handle that abuse they should do just fine.
http://spieglerusa.com/brakes/quick-disconnect.html
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
