03-04-2011, 08:13 AM
gasoline detergent
My engine manufacturer (Aerosport Power) has said that i can use a 91 Octane auto fuel in my O-320 as long as it does not contain ethanol or methanol.
Apparently the 91-octane gas sold by Petro-Canada does not contain ethanol (although I can't find any information about possible methanol content). But it does say it contains Tactrol?, a proprietary deposit control additive, sometimes called a gasoline detergent, that is designed to keep fuel systems clean. Two questions
1) Is there any reason to believe this detergent additive would make the fuel unsafe for aviation use?
2) Is there any issue with mixing 100LL with an auto-fuel like this?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
03-04-2011, 10:05 AM
Phil you shouldn't have any problems. I'm highly certain the mogas I use has the same or similar detergents detergents.
I have always thought that 100LL is just awful fuel. The lead contaminates your oil, forms sludge deposits particularly in the crank, and prevents us from being able to use more modern synthetic oils. Lead spark plug fouling and huge lead deposits on the faces of pistons are common.
With my hodges fuel volatility tester I've only found a marginal difference in safe vapor pressures. In the real world, as others have posted here, you can get vapor lock with 100LL although its much less likely. The main root cause of this is the nature of how our yesteryear fuel systems are designed. Since the pumps draw fuel from the tanks, they work just like the tester does in causing vapor to form...by sucking on the fuel line. If you pump gas from the tanks, under pressure, this will never be a problem. This is why the fuel system in my rocket uses pumps at the tanks which negates the need for a fuel selector.
In your case, as in the case with my flying RV, it doesn't have this type of pump setup, so the best insurance on warmer days to prevent vapor lock is to run the boost pump all the time. I have climbed many times on 95 degree OAT days to altitude with the boost pump on, and have had no problems. But I found this out inadvertently one day when I forgot to turn the boost pump on, and was climbing out and started to get a rough running engine. Turning on the boost pump instantly took care of the rough running.
Another area when I do have had an occasional problem is with a quick turnaround on a hot day. Since fuel is sitting in the carburetor bowl boiling, it will be difficult to start and once it does start, the engine will want to quit taxiing out. The easy cure for this is to open the oil door after landing to mitigate heat soaking the engine compartment. Seems to work for me.
The other time I have had vapor issues is when taxiing out on a hot day, and have been held by a controller or traffic with an extended period of idling. Running the power up to 1200-1500 rpm will mitigate this problem by forcing that nice fan up front to cool things.
As far as octane goes, everyone seems to say only use premium fuel. I have not found regular 87 octane to be detrimental in any way.
On our airpark we have a 500gal tank I fill up from. On a trip to NC last November I had difficulties starting and thats the only time in almost ten years I've had that problem, and I attribute it to bad gas. Our tank was running low and the fuel in it was a couple of months old.
You certainly can mix the fuels as I have to all the time on trips where mogas is unavailable.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
03-04-2011, 10:47 AM
Originally Posted by rocketbob
Stuff deleted...
...and prevents us from being able to use more modern synthetic oils.
Hey Bob
Could you expand upon this statement a little? What about semi-synthetic oils?
Mark
RV-8 C-GURV (Flying since Nov 2004) - Sold
Scratch building 4pl Bearhawk
Flying a '79 Maule M5-235C
President EAA Chapter 245
03-04-2011, 11:12 AM
...As far as octane goes, everyone seems to say only use premium fuel. I have not found regular 87 octane to be detrimental in any way...
Originally Posted by lcnmrv8r
... Fyi, I use 87 all the time with no issues. My fuel economy is slightly less with the 87 but not enough to offset the cost.
What compression ratios are your engines?
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
03-04-2011, 11:20 AM
for me, stock... 8.5:1
N8155F C150 flying
03-04-2011, 11:22 AM
Originally Posted by rv8bldr
Hey Bob
I'm really talking about full synthetics. Like the old Mobil1 that got pulled years ago due to lead scavenging problems.
N8155F C150 flying
03-04-2011, 11:26 AM
The problem with synthetic oils is they don't hold contaminants in suspension very well which leads to sludge build-up, among other bad things. Sludge build-up can lead to blocked oil passages, loss of oil distribution and then expensive engine repairs. This is why Mobil AV-1 was removed from the market. Not an issue in cars mainly because mogas burns much cleaner due to its formulation without lead.
Here's a good article on the subject out of SportAviation by Mike Busch: http://www.sportaviationonline.org/s...pm=2&u1=friend
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
03-04-2011, 02:46 PM
Synthetic OIL
I think full synthetics are still alive and well in the turbine market. Semi-synthetics are used in lead powered recips. Exxon is selling 'Elite' blended weight that is a semi-synthetic promising to bring some of the advantages of both worlds.
John D. Artz, EAA 71811, 100+ Young Eagle flts
Adopted Dave's 6A
MXL Ultralight, only bleeding after 3 landings
Scorpion Two Helicopter, big mistake
PA-28 and 210E Centurion
03-04-2011, 03:04 PM
Yep... no lead in Jet-A.
N8155F C150 flying
03-04-2011, 09:07 PM
Bob,
You happened to bring out the number one reason I won't use autogas its the problem of "old gas".
From my understanding, auto fuel begins to breakdown almost from the point of refining, whereas I have read that avgas can be stored and used safely up to 2 years and perhaps a little longer.
My airplane has sometimes sat for a couple of months and much longer when I did a panel rebuild years ago.
I just don't want to take the chance of having my fuel system loaded with crud because of old car gas and the safety problems that come with it.
Never a problem with avgas
YMMV,
Glenn Wilkinson
_____________________________________________
RV-4 Sold
N654RV @ MLJ
RV-7 Coming Soon
N987RV Reserved
2015 Donation Gladly Paid
"Maintain Thy Airspeed, Lest the Earth Arise and Smite Thee"
