03-02-2011, 07:38 PM
Leak? Condensation?
I did not build my 6A, so I apologize in advance for not using the right terms, but will try my best...
I have noticed a very small amount of "liquid" seeping out from under my wing/fuse fairing on to the bottom of the port wing. The stain travels almost to the flaps after long flights. I removed the bottom part of the wing/fuselage fairing to expose the part of the tank that faces the fuse. I have taken a mirror and looked along the back of the tank...no visible leaks. No leaks also visible on the vent or main fuel coupling...or anywhere on the tank that I can see. I have pressured the vent line significantly and let sit for 45 minutes to an hour.....no leaks and the pressure relieves after sitting for the duration. HOWEVER, after flying the small amt. of seepage appears. After several hangar buddies got on the creeper and assessed the situation, some thought there was condensation coming from the tank or maybe the main line leading to the fuse. The condensation drips and the liquid trail forms. The liquid is always dried by the time I crawl out and remove the fairing....and the stain residue is odorless. I keep in a hangar that is somewhat cooler than outside ambient.
Has anyone experienced this???
03-02-2011, 07:40 PM
been here awhile
What color is the stain?
03-02-2011, 08:11 PM
Color
I had compounded the paint and left some under the fairing.... it was the blue color of the compound.
03-02-2011, 08:25 PM
Senior Curmudgeon
Blue stain is also the color of 100ll fuel.
You might want to be really sure this is not a fuel leak----clean everything well, put it back together, and keep an eye on it.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
03-03-2011, 10:25 AM
blue sounds like 100LL to me.... does it smell like avgas?
Andrew
Lancaster, PA l RV-7 #3898 l Empennage l N627AB
"I fly because it releases my mind from the tyranny of petty things" ~Antoine de Saint-Exupery
03-03-2011, 12:36 PM
Blue
It does not smell like avgas
The blue for sure is from the compound material that worked its way under the fairing.
I'm thinking of wrapping the area...vent and fuel lines under the fairing with a paper that discolors when wet, seal it back up and see what happens after a flight.
03-10-2011, 09:20 PM
It's a Leak
So I cleaned off all the compound and stuffed some Kleenex behind the rear tank baffle and went for a one hour flight. Soaked up a quarter-size of fuel over two spots on the bottom/rear portion of the baffle...very slight. I can't pressurize the tank and get it to leak...only in flight.
After reading various methods of fixing this, I am thinking about removing the tank.
Other than the perimeter screws and the connections at the root, what is holding this tank on? Anything through the spar?
6A-Slow Build
03-10-2011, 09:26 PM
Other than the perimeter screws and the connections at the root, what is holding this wing on? Anything through the spar?
Just the screws & root bolt you mentioned.
L.Adamson --- RV6A
03-11-2011, 10:32 AM
L.Adamson --- RV6A
Does the 6 not use Z-brackets and bolts through the spar?
03-11-2011, 10:35 AM
Nope!!!!!!
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
