Go Back   VAF Forums > RV Firewall Forward Section > Fuel Injection Systems
  #11
Old 03-03-2011, 09:40 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Originally Posted by ronschreck View Post
Mike, since you recommend
Not recommend, just a report of what I do.
leaving the valve closed after engine shutdown it is implied that there you have no spring on the valve actuator arm to hold it open. This is a safety issue since failure of the cable attachment to the purge valve could allow the valve to close in flight resulting in fuel starvation to the engine. A return spring should always be attached to the purge valve actuating arm to hold it open.
There is a spring, and if the cable breaks off at the valve, it will keep the fuel flowing. The friction of the cable is enough to override the spring, keeping the valve in bypass mode when parked.
Good eye here, this is an important safety issue as you said, and is worthy of repeating. Thanks for catching that.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 03-03-2011, 09:57 AM
erich weaver's Avatar
Hey Don
Curious as to why your procedures have the purge valve at ICO when cranking. Just a precaution to avoid flooding if the engine doesnt start right away? I dont do this and havent had any problems, but Im sure you have your reasons.
thanks
erich
Old 03-03-2011, 12:26 PM
Don at Airflow Don at Airflow is offline
Default Cranking in rich position
Exactly. If the engine does not start there is fuel going in the engine, and when you stop cranking the engine driven pump continues to put one stroke of additional fuel in the engine. Fuel will be running out the intake. Not good
Don
Old 08-27-2011, 01:10 PM
akschu's Avatar
akschu akschu is offline
Does the afp system use a prime pump like on a carb'd engine or is the boost pump the fuel primer?
Old 08-27-2011, 02:34 PM
N15JB N15JB is offline
The boost pump provides priming.
Jim Berry
RV-10
Old 08-27-2011, 03:04 PM
akschu's Avatar
So those that mean those that converted from carb to afp can use the hole in the panel that was for the primer for the purge valve? I just want to make sure I get this right on my panel drawing.
Old 08-27-2011, 09:02 PM
The only thing better than the purge valve is a cold beer.
Yes, on the former primer hole. A good place for the purge valve.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
