Old 03-02-2011, 04:45 PM
miyu1975's Avatar
miyu1975 miyu1975 is offline
Default mechanical fuel pump tricks
Installing my new fuel pump has been more or a challenge than I planned. Having a hard time lining up the actuatur arm and pin lined up and getting the bolts in. Anyone have any tricks/tips on this.?
Ryan Allen, CFII
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 90%, fuse on order
Acro Sport 2, building
Old 03-02-2011, 05:02 PM
Walt's Avatar
Walt Walt is offline
Make sure the arm is all the way up by rotating the engine while feeling it (having the plugs out makes this much easier). Make sure the pump goes straight in and is not cocked to the side. Get the bolts started and work them in evenly and slowly, from there it should go in with very little resistance.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 03-02-2011, 05:12 PM
petehowell's Avatar
Default Previous effort here...
Old Thread
Pete
Amateur Radio - KD0CVN
Doggies Delivered - 25+
St. Paul, MN
Old 03-02-2011, 05:48 PM
miyu1975's Avatar
Great...thank you. I got it installed. My engine is still on the stand so access was not an issue. I needed to turn the engine to shorten the plunger. After that I got it on with no prob. thx again
Ryan Allen, CFII
E-170/175
Old 03-02-2011, 07:45 PM
AlexPeterson's Avatar
Originally Posted by petehowell View Post
Pete, you dredged up old horror memories... hard to believe that was four years ago!
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
