Old 03-02-2011, 11:01 AM
Randy Means Randy Means is offline
Default Jack for a RV-10
Having finished N595RV last July I am in need of good information on how to jack up the beast safely. Welcome any suggestions.
Randy Means
N595RV
Old 03-02-2011, 11:09 AM
Vern's Avatar
Vern Vern is offline
Default Homemade jacks
We made home made jacks using inexpensive Harbor Frt straight jacks. We made a 18" square floor plate of 1" plywood and used hose clamps and 45 degree members made of conduit pipe. Works great!
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
Old 03-02-2011, 03:03 PM
pierre smith's Avatar
Default Two concrete blocks.....
...a piece of 2" X 6" and a bottle jack. Screw bolts in the tiedown holes and....voila!
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 03-02-2011, 03:13 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Harbor Freight jack, scrap steel.
I took a piece of 2x6" about 8" long, and used a hole saw to cut a pocket in it that would fit over the jack ram----only 1/4" or so deep-----to keep the board from slipping off the ram.
I span the two spars with the 2x6 blocks, locate the ram under the rear spar.
I slid some scrap alum strips between the skin, and the spar so I would not dent the skin.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
