Whoa, there! Misconception correction. If you want to burn mogas, you're not stuck with a 320. 360s burn it just fine, too. They share compression ratios. If that's the big swinger for you, get the 360. Nearly the same cost, and fuel burn can be made almost equal for the same speed. But the 320 will always be the weaker motor.
John Siebold
