Old 03-01-2011, 07:02 AM
gereed75 gereed75 is offline
Default Great pilot's bifocal sunglasses
Found some great pilot's bifocal sunglasses while in the fishing store (Bass Pro) -I-GOGS.
What makes them great is that the bifocal portion is clear glass (no tint or polarization). That means that when you look up, you have polarized sunglasses, when you look down, you have non-polarized, non-darkened, close magnification. These were designed for fishermen so that when they look down at their GPS units, they can see them clearly. Often these are hard to see because of the polarized interference.
Works great for us in the cockpit too!!
Available in sport stores, list $20.00.
Gary Reed
RV-6 IO-360
WW 200 RV now an Al Hartzell for improved CG
Old 03-01-2011, 12:16 PM
rv7boy's Avatar
rv7boy rv7boy is offline
Forum Peruser
Default polarized sunglasses
At one time, polarized sunglasses were a "no-no" in an airplane cockpit due to the combination of polarized lens and the windshield at just the right angle causing blind spots out there in the distance. I don't know if this is an old wives' tale or if there is some truth to it, but I've stayed away from the polarized lenses for about 25 years.
Hazebusters sells some really good bifocal sunglasses. They used to advertise here but I'm not sure if they do anymore. Customer service is fantastic as well.
Here's a brief technical article on the AOA page. The third bullet discusses the possibility of a "reduced retinal image" with polarized lenses behind an aircraft windshield. Dr. Nakagawara is or was head of the FAA's vision group at OKC.
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
Old 03-01-2011, 01:23 PM
flyboy1963's Avatar
Default Beware the $20 lense
I have not seen the I-gogs, they may be great, but the fishin' glasses I've seen had really crappy molded in bifocal 'dots' on the lower lense, and where they transitioned back to the regular lens, the distortion was terrible!
My optometrist told me to do this test, to avoid eyestrain, and generally identify cheap molded, not ground, lenses.
Hold the glasses horizontally, in front of you like you are reading a book.....( so that you can see the reflection of overhead lights in the store.)
Roll the glasses slowly so that the reflection moves from edge to edge & around the entire lens. You'll quickly see where the image distorts, and while not immediately noticable in use, you may wonder why you get eyestrain only when wearing them, and not your Serengeti or Ray-bans!
Intersting article with info on light transmittance....since we all wear shades, and then fly under clouds etc. where they are not much help.
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 03-01-2011, 01:58 PM
Mark Burns's Avatar
Mark Burns Mark Burns is offline
Default Just in case
Just in case you want to try the $20 lense
Here's where I buy mine. www.boomersintheknow.com
I've had good luck.
Mark
Mark Burns
Ruston, Louisiana
RV-7A N781CM 1,650+ hrs
FFI FL-24
A&P
Old 03-02-2011, 02:13 PM
flytoboat's Avatar
flytoboat flytoboat is offline
+1 for the Hazebusters. I've had mine for 2 years and love them in the auto. I had to get trifocals for different distance for reading dash instruments as opposed to reading charts so don't use them in the plane but if you only need one magnification they are great and positioned perfectly for the airplane dash.
Don
VAF #1100, EAA864
-6A bought flying
Old 03-02-2011, 04:25 PM
Alan Carroll's Avatar
Alan Carroll Alan Carroll is offline
Default Not all alike?
I've had good luck with these:
http://www.eyeneeds1.com/bostrxtibi.html
The bifocal lens appears to be bonded on rather than molded, and they pass the distortion test described above.
Alan Carroll
RV-8 N12AC
Old 03-02-2011, 04:39 PM
Scott Hersha Scott Hersha is offline
Another cheap source for reader sunglasses (and clear, for the shop). Check the different brands and look for the reader, or bifocal ones. All are safety glasses too and are cheap enough to have several. I've been buying them for years.
http://www.safetyglassesusa.com/
I like the wrap around kind. They keep the glare out.
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
Cincinnati, OH/KHAO
JAN2020
Old 03-04-2011, 10:02 PM
SHIPCHIEF SHIPCHIEF is offline
I like the UVEX brand, the 1.5 diopter sunglasses are distortion free and they fit well inside the headphones (for the first few hours).
They have many styles, shades and magnifications.They don't look like horrible old safety glasses, although they do make some large ones that fit over your prescription glasses as well.
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
Old 03-04-2011, 10:38 PM
Jim Percy Jim Percy is offline
I have a pair of Hazebusters and I think the quality is top notch, but I prefer a wrap-around style that they don't have. I recently got some of these and really like them. The optical quality seems good and the bifocal is essentially invisible from the front. Non-polarized.
http://www.amazon.com/Sunglasses-low...9302835&sr=8-3
Jim Percy
SoCal
FFI Wingman
RV-7A, XP-O-360
Old 03-05-2011, 06:40 AM
rv8guy's Avatar
rv8guy rv8guy is offline
I would advise care if you look into polarized. If I wear them, the display on the SL30 ans SL70 goes completely dark, unless I tilt my head sideways at 90 degrees. I also had an experience awhile back on a bfr when the CFI thought i was crazy, but I didn't see the comm radio in his 172 due to the polaroid glasses. So just check your panel first!!
I wear prescription trifocals and have them made clear on the bottom, perfect for my 8.
Marshall Jacobson
"Miss Sue"
RV-8 80749 slow build taildragger
7.5 year build first flight Dec 2005
SOLD at 540 hours and 10 years of FUN
N68AK
Watkinsville, Georgia
