I am just beginning this very task myself, with an RV-9A. The A models, with the nosegear, are more difficult because the fuel line (and brake line) have to run around or through the main landing gear weldment.
I found a couple of URLs that might help you even if you're not building the A model, it's the technique that can be useful:
http://www.europa.com/~swayze/RV-7A/.../20100528.html
http://www.vansairforce.com/communit...eferrerid=8660
However: I tried the technique yesterday and couldn't quite make it work. I think you need strong hands to make the bends between the gear weldment and the fuselage exit hole. Besides, I wanted to use 5052 Al tubing instead of the softer tubing Vans supplies (6061 I think).
So instead I bent some copper wire as a model, then bent the Al tube with a lever-style tube bender. Worked fine, all I have to do is the last subtle bends to get through the two braces and their nylon snap grommets. I haven't bolted in my landing gear weldment yet. The techniques in the URLs above seem to work with the weldment in place.
BTW, why would a connector at the fuselage side help? Once you're there, it's a short straight exit to the wing and the fuel tank.
