Old 02-28-2011, 02:19 PM
RobinHou RobinHou is offline
Default Electric Drill Bit Sharpener
Has anyone had experience with this:
http://www.harborfreight.com/electri...campaign=0911a
Any comment is appreciated.
Robin
Old 02-28-2011, 02:47 PM
flion's Avatar
flion flion is offline
I've always agreed with the guy (was it Tony Bingelis?) who said the proper way to sharpen a drill bit is to cup it in the index and middle fingers, with the thumb resting lightly on top ... and then pitch it underhanded into the nearest trash bin. Bits are relatively cheap.
Sorry, that was sideways to your question. You can guess that I have absolutely no experience with an electric sharpener of any make.
EAA Technical Counselor #5357
Old 02-28-2011, 02:55 PM
rv9aviator rv9aviator is offline
I use a Drill Doctor in my machine shop and it works pretty good. I have no experience with the Harbor Freight model. Anything under 1/4 inch is really not worth messing with in my opinion. I bet I haven't used 6 or 8 of the #40 and #30 drills used for riveting in my whole RV-9 build.
Jim Wright
RV-9A N9JW 90919 SoldArkansas
http://www.jimsairplanes.com
_______________________
"It's a brutal struggle for the biscuit."
Old 02-28-2011, 03:14 PM
dlloyd3's Avatar
dlloyd3 dlloyd3 is offline
Default No, no, nooo
Instructions that came with the Harbor Freight sharpener did not help in understanding how to make it sharpen a drill bit (wear goggles, don't run with scissors, etc.). Never did figure out how to make it sharpen but did dull quite a few. Save your money, buy new bits.
Dave
M20C
Old 02-28-2011, 03:28 PM
rv7boy's Avatar
rv7boy rv7boy is offline
Forum Peruser
118 deg or 135 deg??
suitable for split-point?
Save your money and buy more drills from Avery, or Cleaveland or some other reputable aircraft tool dealer.
Just my opinion.
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
Old 02-28-2011, 04:44 PM
jrs14855 jrs14855 is offline
Default drills
Small drills go in the trash. Five years in a machine shop I am reasonably good at sharpening the larger bits, lets say 3/16 and larger, freehand on a bench grinder, finish with fine grit wheel. The secret to the larger bits is a trial run on a scrap of thick aluminum to see if they cut evenly on both flutes. If not regrind and try again. Mark the side thats cutting and take a tiny bit off that side.
Old 02-28-2011, 06:36 PM
E. D. Eliot E. D. Eliot is offline
Default Drill DR
Purchased the middle of the line Drill Dr (about $150) a few years ago. Found that it was a waste of my cash - works ok on bits 3/8" and larger but not very well on the size of bit that we use on aircraft.
My opinion - don't waste your money on drill sharpeners.
Old 03-01-2011, 06:52 AM
Scott Hersha Scott Hersha is offline
If you still want to sharpen your bits, I'll make you a good deal on my Drill Dr.
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
Cincinnati, OH/KHAO
JAN2020
Old 03-01-2011, 01:33 PM
Cadstat's Avatar
Cadstat Cadstat is offline
Default Drill Doctor
Works great but you have to develop a 'feel' for using it. It's fine for polishing up some tips that don't cut like new. The cobalt drill bits will last until you lose them. It's all about the pressure and feed of the material. They all cut steel for a long time. even stainless. if you use a little oil.
John D. Artz, EAA 71811, 100+ Young Eagle flts
Adopted Dave's 6A
MXL Ultralight, only bleeding after 3 landings
Scorpion Two Helicopter, big mistake
PA-28 and 210E Centurion
