Old 02-27-2011, 09:27 PM
roadrunner20's Avatar
roadrunner20 roadrunner20 is offline
Default Strobe service life
I'm using a Nova AVI-PAK that just died. I purchased it from CreativAir about 6 years ago.
Anyone have any idea of the service life of these power supplies?
I'm approaching 600 hours.
I saw a post in the archives that Nova has a low cost replacement 604HR.
It was an old post so I'm not sure it's still available.
Update: Just checked Aircraft Spruce and they have the 604-HR + the light assembly for $399.
I don't see the power supply separately.
Is anyone using this setup?
Danny "RoadRunner" Landry
Morphed RV7(formally 7A), N20DL, PnP Pilot
1190+ hours
2019 Donation Paid
Old 02-27-2011, 10:15 PM
chaskuss chaskuss is offline
Default Two low cost sources for the Nova 604
Dan,
Strobes and More has the Nova 604 power supply for $134.99 See
http://www.strobesnmore.com/nova-x-p...-supplies.html
Pricing and ordering is found at the bottom of the web link.
Roper has the same power supply for $122.75 See
http://www.ropersupply.com/index.php...roducts_id=263
Charlie
PS I had just researched this for a local RV6A owner two days ago.
Old 02-28-2011, 06:24 PM
Originally Posted by chaskuss View Post
Dan,
Charlie
Thanks. I did talk to Strobesnmore today.
But, from my understanding is that the XPACK604X flash rate is too fast for aviation.
Archive posts recommended the XPAK604X-HR which means "half rate"
I talked to this company today. GS-Air.com.
Here's their product although they were out of stock and due in any day.
https://ssl.perfora.net/www.gs-air.c...dex.shopscript
1190+ hours
2019 Donation Paid
Old 02-28-2011, 08:19 PM
Originally Posted by DanLandry View Post
Thanks. I did talk to StrobesNmore today.
Dan,
Are all 15 flash patterns to rapid? I've never heard of this issue before [but that doesn't mean anything] Can you expand on the flash rate? I was unaware that the HR power supplies even existed. I'm curious about GS Air's claim that their Nova power supply can run 3 or 4 strobe heads [bulbs] at full power. 4 strobes is the maximum for the 604.
Nova's literature for my 906 states that running more than three strobe heads [out of a possible 6] will cause the power to be shared. This will reduce the power [and brightness] of each individual strobe.
Old 02-28-2011, 08:52 PM
Default I've never seen a Nova system like this before
snipped
snipped
Dan,
I just found a system from the company GS Air you linked to earlier. They have a complete system PLUS L.E.D. position lights for the same $399 you quoted from ACS. The power supply alone is $159 Does the ACS system come with the position lamps?
I tried to provide the direct link, but it won't work. I did a search on the GS-Air site for XPak-604-HR and both the complete system and the power supply alone came up.
Charlie
Old 02-28-2011, 09:57 PM
Dan,
Charlie
Here's the link to ACS. The complete system is $399.
http://www.aircraftspruce.com/catalo...es/ledtaxi.php
1190+ hours
2019 Donation Paid
Old 02-28-2011, 10:04 PM
Dan,
I can't expand on the flash rate other than I believe I read that the 604X flashes around 100-140 times per minute and is too fast according to the FARs. Don't take my word for it but can find more info in the thread below. I picked up the 'Half Rate' HR, from other postings on the Matronics site and the VAF thread. It's old but a lengthy discussion.
http://www.vansairforce.com/communit...ghlight=604-hr
1190+ hours
2019 Donation Paid
Old 03-01-2011, 06:29 PM
Default Ahhh! The pain.
LENGTHY? H**L, my eyes are now square, from reading that thread! Thanks for pointing it out.
Charlie
