It might be a problem with the electricity to the motor. It sounds like once pressure builds up, the motor cannot handle the additional load and is bogging down. Does the breaker eventually trip when the motor stalls?
From my experiences, it sounds like the problem can be
1. Not enough power (amps) coming from your house to the high demands of the compressor.
2. The motor needs rebuilt
3. The Check Valve is no longer working properly
That is probably why it was given to you.
What type, size, compressor is it? How many Volts? Can you hook up a volt meter to it and monitor the change when this happens?
Rick from Fresno
RV-7A
The art to flying lies in learning how to throw yourself at the ground and miss.
