02-27-2011, 09:05 AM
time until first plug cleaning?
I've got about 35 hours on the plane now. This spring/summer, probably when I get close to 50 hours, I plan to hire a local retired AME to teach me how to do a major inspection including mag timing check, compression test, etc.
Question - am i ok to wait to 50 hours to do my first spark plug inspection and cleaning? I've been running mineral oil, and am just now changing to Aeroshell W 15W50 (what does the leading "W" indicate, by the way?).
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
02-27-2011, 09:09 AM
15 winter weight, 50 summer weight.
Basically, it is a multiviscosity oil. Cold, it exhibits the properties of a 15 weight oil. hot, it exhibits the properties of a 50 weight oil.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
02-27-2011, 09:35 AM
IMHO, 50 hours is generally a very reasonable period to go before cleaning the (conventional massive electrode) spark plugs unless they are somehow getting excessive carbon and lead deposits in them prematurely.
At the first 50 hours in the RV-8 in my avatar (new ECI IO-360 engine), the plugs were still so clean and devoid of any lead or carbon deposits that we just simply checked the gaps and put them back in and waited until 100 hours before running them thru the abrasive plug cleaner. They were even still very clean then. Every time you beadblast them with an abrasive spark plug cleaner, you remove some amount of potential useful service life from them, so you really don't want to beadblast them too frequently if they don't need it... especially for how expensive spark plugs are these days to replace. The high-dollar platinum or iridium fine wire plugs have been known to be able to go to full TBO (2000 hours) without cleaning!
Neal Howard
Airplaneless once again...
02-27-2011, 10:04 AM
every 100 hrs.......
clean with dental pick, regap, and rotate, thats it. FLY ON!!!!!
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
