Old 02-26-2011, 09:28 PM
Flying Scotsman Flying Scotsman is offline
Default 5702-x-y washers
Quick question...search turns up no info...
The little itsy bitsy teeny weeny washers that Van's calls for on the sides of the rod ends, to space them out...
5702-something-something else (e.g. 5702-75-60)...
Do those those have an AN or NAS or other part number? If I wanted to order them from somewhere else, say, ACS or GAHCO or wherever, what part number would I use? Can't find any info via internet search...
TIA!
Steve
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
Old 02-27-2011, 09:07 AM
az_gila's Avatar
az_gila az_gila is offline
Post
TIA!
Steve
No easy commercial equivalent AFAIK, and no AN/MS equivalent.
They might even be better described as short spacers rather than washers...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 09-12-2017, 03:55 PM
scsmith scsmith is offline
Default spacer washers
I was skulking around trying to find someplace that would mention the thickness of the 5702-75-60 spacer washers that Van's sells for spacers used with spherical bearings, since I didn't have one handy to measure.
I stumbled on a drawing from a source that is in Idaho. I'm guessing this is where Van gets those spacer washers. The dimensions match.
Here is the link:
http://www.seastrom-mfg.com/urltopdf...=5702-75-60-Z3
Just in case this helps someone down the road.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
