Old 02-25-2011, 12:51 PM
airguy's Avatar
airguy airguy is offline
Default Interesting build-for-hire question
I was recently contacted via a friend in Russia by a gentleman looking to sell his RV. Here's the deal - it was built in Russia (Ukraine, I believe?) by a build-for-hire guy, sold to a private owner in Russia, and now that private owner is looking for a buyer (unknown how long he has owned it). It's a standard-plans 7 with O-360, VFR panel and FP prop. What is the legality of importing and registering that aircraft in the US?
Old 02-25-2011, 01:51 PM
Vern's Avatar
Vern Vern is offline
Default Importing
FAA 8130.2F Change 5 , Chapter 6-IMPORT PROCEDURES might be a good starting point. I'd sure meet with FSDO folks and agree in writing what procedures you should follow.
Change 6 is due out soon.
You can download a pdf at FAA.Gov
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
Old 02-25-2011, 02:07 PM
Kahuna's Avatar
Kahuna Kahuna is online now
Been beat here before.
Search import experimental and you can see the previous discussions, including this one from russia.
Kahuna
6A, S8 ,
Gold Hill, NC25
Old 02-25-2011, 04:52 PM
Mel's Avatar
Mel Mel is offline
To be eligible for import as experimental amateur-built in the US, the aircraft must meet all US regulations. This aircraft would seem to NOT meet the amateur-built criteria.
See FAA Order 8130.2F, Section 9, Paragraph 152.k
k. Special Considerations. In addition to the above certification requirements, if an applicant’s
aircraft is an unevaluated foreign amateur-built kit, the FAA must perform a major portion
determination using the Amateur-Built Aircraft Fabrication and Assembly Checklist (2009).
If compliance to the major portion requirement of § 21.191(g) cannot be ascertained, a special
airworthiness certificate for the purpose of operating amateur-built aircraft must not be issued.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 02-25-2011, 05:08 PM
Mel's Avatar
Mel Mel is offline
Default Actually....
It's not change 6. It is revision G. It is already out and becomes effective 4/16/2011.
Old 02-25-2011, 08:14 PM
LifeisGood's Avatar
LifeisGood LifeisGood is offline
Thank you Mel and Vern for actually answering the question......
