Old 02-24-2011, 07:28 PM
albertaflyer albertaflyer is offline
Default Adding Aero LED's after the fact
How hard is it to swap out the standard wingtip position lights and tail light for the aero LED's system? From my understanding I would have to feed another wire for the wing tip strobes... is this possible?
Old 02-24-2011, 07:36 PM
Snowflake's Avatar
Depends how you attached your wires... You could disconnect the existing wire at the wingtip, attach a string to it, and pull the wire back out to the root. Then attach a second wire to the string, and pull the string back out to the wingtip. Presto, now you have another wire at the wing tip.
Rob Prior
Old 02-25-2011, 10:21 AM
That's the problem I never built it so I guess I'll have to pull a wingtip and see
