Back on track
I made a phone call today and found out ECI is offering an O-340 carbed version to go along with the IO-340. Also there are two sumps in the line up. One with cooling fins (which I doubt will do too much since there is little airflow there) and one without. I guess the sump with the fins is an inch taller than the plain one which may cause a problem in certain applications. The suggested TBO is 2000 hours.
Bruce Smith
Clearwater, FL
RV-7A Fuse
N27DB reserved
web.tampabay.rr.com/flrv7a
"Political correctness is tyranny with manners."
Charlton Heston
