I did not realize that 496 was mono only, just bought a 3.5 mm stereo plug, one less wire to solder on I guess.
I am not sure I understand how you say you can turn alerts off with the way you wired the 496, do you mean you just deselect that input on your intercom.
My plan is to wire music input 1 to the 496 on my Garmin 240 audio panel. The only way I see to disable alert other than in the 496 menu is to deselect music 1 input on the intercom, of course the would inhibit XM Music as well.
So the XM music out of the 496 is mono only? Did not know that. So with the way you wired this will you only hear XM music on one side of your headset?
Cheers
Originally Posted by Wayne Gillispie
short pigtail with 3.5 mm 90 degree stereo jack into a shielded wire which then runs back to my PSE 8000B audio panel entertainment inputs. Wired to audio low and audio left. The 496 has mono output only. This way I can switch the alerts off if I choose too.
