Old 02-22-2011, 07:36 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Default RV Engine Mounts
I was wondering the degree offset for the Van's engine mounts? Are they all the same? Also, what is or should be the degree or angle of the crankshaft (horizonal) say the prop extension measured with an angle finder in relation to level flight? (I believe Van's states the longerons are level in level flight mode)... Russ, are you out there?
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 02-23-2011, 02:27 AM
Russ McCutcheon's Avatar
Russ McCutcheon Russ McCutcheon is offline
Hi D,
As it applies to engine mounts, we only build the RV-4 mounts and I don?t even know the answer for that one, I started working for Lee 20 years ago, 1991, he built the engine mount jig in about 1982, we did make some changes to the jig in the early 90s to accommodate the new long gear legs but otherwise I have never had a need to know the answer to your question, we still use the same jig to this day. You better look up an old set of -4 or -6 planes I bet it?s on there.
Russ
Russ McCutcheon
@rv4welder on Facebook
russmccutcheon@gmail.com
We build many of your RV weldments.
Old 02-23-2011, 07:40 AM
Default Well...
looks like I need to pitch this one straight to Van's...
Reiley
VAF# 671
Friend of the RV-1
Old 02-24-2011, 07:42 PM
Default Well...
info came back from Van's engineering today.
Answer: Engine Mounts are set-up 1.25 degrees offset to the right (horizonal) and 0 degrees offset in the up or down (vertical) level flight.
I took the 'ole smart level to the vertical offset (crankshaft flange) and referenced it to the longerons (level flight reference neutral) and sure enough dead on 0 degrees.
Next, to fly the plane with the smart level inside the cockpit, level flight and record this info.
Reiley
VAF# 671
Friend of the RV-1
Old 02-24-2011, 08:33 PM
Just curious. To what end?
Russ McCutcheon
Old 02-25-2011, 07:26 AM
Just playing with Speeds and Mods, Props and a few other things.
Reiley
VAF# 671
Friend of the RV-1
Old 02-25-2011, 09:41 AM
Sounds fun!
Russ McCutcheon
