Go Back   VAF Forums > Model Specific > RV-6/6A
Old 02-22-2011, 06:49 PM
Bad Sheila's Avatar
Bad Sheila Bad Sheila is offline
Default RV-6 HOW TO: Wing wiring for Heated Pitot & AOA tube
How do I run wing wiring for Heated Pitot & an AOA tube to my Dynon heated pitot?
Any help would be appreciated
Old 02-22-2011, 07:07 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
If you already have conduit in the wing, tie a string to a cotton ball and suck it thru with a shop vac... then tie your wires on the end of the string and pull them.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 02-22-2011, 10:34 PM
Bob'sRV6A Bob'sRV6A is offline
Default Just planning mine now:
I'll use #18 AWG for the black (back to firewall ground) and red 14V, and #22 for the white signal wire that goes to the EMS.
Per instructions, I'll run the heater off a switch/10A fuse with the on/off warning feature shown on the skyview. I am going to order Van's corregated plastic conduit http://www.vansaircraft.com/cgi-bin/...wiring-conduit
Hope this helps,
Bob
Old 05-19-2011, 07:02 PM
Bad Sheila's Avatar
Default Heater Unit
Where have you put the sender unit for the heater. They say as close as possible but I have had to put the pitot inside the wing inspection plate. I have to put it in the wing-tip or the fuselage. where have you got yours?
Old 05-20-2011, 07:23 AM
cfiidon's Avatar
cfiidon cfiidon is offline
Default My example
In this first photo you can see inside the outermost inspection port of my -8 wing (looking in and aft as it sits in the cradle). I mounted the controller here on small standoffs made from aluminum tube to clear the "bump" on the rib.
In the second image you can see how I mounted the pitot assembly, one bay outside the inspection access hole. This location has it's pluses and minuses... with it here the tie-down rope or chain "might" interfere if you are not careful. I ran the tubing for the pressure and AOA thru the pre-punched holes in all the ribs. I ran the wiring thru a third row of holes, although I had to open up the holes in the innermost four ribs. Don't think I have a pic of that, although I can tell you I used a very long drill bit to do so.
Hope this helps.
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
Old 05-20-2011, 12:12 PM
Bad Sheila's Avatar
Default Pitot Wiring
Don,
Thanks for photos. Did you use conduit for the tubing and why a 3rd hole for the wiring?
Old 05-20-2011, 07:35 PM
cfiidon's Avatar
Default Dredging up the memory cells
If I recall correctly, there are three holes in each rib just aft of the spar (don't know if yours differs). Only one hole was large enough for a bushing. I put bushings in the center large hole and ran wire thru there. I did install conduit for other wiring in the aft portion of the wing.
When I ran the Pitot and AOA tubes I decided to drill out the other two holes and also install snap bushing. You can probably see them in my photo. Rather than go thru conduit in the lightening holes, I opted to spend a little time and make use of those holes.
It can be done with the right drill (an angle adapter helped) and a long bit for the closely spaced ribs near the wing root.
Have fun.
Don
