Old 02-20-2011, 04:35 PM
avq avq is offline
Default procedure for removing cylinder hold down studs?
Does anyone have a good procedure for removing (and installing) cylinder hold down studs on an O-320 case? I have a couple of 3/8th studs that need to be replaced because the threads are badly damaged.
I already sent the case to get overhauled and most damaged studs were replaced but two were missed.
I was thinking of getting one of these collets with the appropriate housing but I am not sure if there is something better out there.
http://www.sears.com/shc/s/p_10153_12605_SPM250268727P
Anton
Old 02-20-2011, 04:48 PM
Sid Lambert Sid Lambert is offline
Why not just use 2 nuts?
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
Old 02-20-2011, 05:12 PM
rocketbob's Avatar
Anton
You're on it...these are the right (and best) tools for removing/installing studs.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 02-20-2011, 05:16 PM
avq avq is offline
I tried this but I could not get enough torque to pull out the stud with the open end wrenches. My next plan is to use a longer wrench
Old 02-20-2011, 05:58 PM
avq avq is offline
Thanks Bob. I am just going to pull the trigger on the order. It has been sitting in my cart for a couple of days now.
Should I heat the area before attempting to remove the stud?
Anton
