AN hose fitting adapter for oil cooler
I need help in trying to locate an adapter of some type to connect my new oil line to my oil cooler. After 28 years of service my oil lines need to be replaced. The original lines have -8D connector on the end that attaches to the engine, and 1 -6D (3/8") connector which which connects to the oil cooler. The oil cooler has male flared -6D fittings on it, and I have not been able to find any adapter or part number for something that can transition from -8D to -6D. The closest I have been able to get is an AN male reducer that converts the female -8D fitting on the hose to a -6D flared male end. What I am looking for is either a -6D female/female adapter (for flared fittings), or and adapter with a -8D male flared end with a -6D flared female end.... or of course another workable solution.
Any help is greatly appreciated
RV-3 (with Harmon Rocket fastback) - 645hrs.
Catto 3 Blade
Horsepower - More! (see below)
More electronics than the Space Shuttle!
Horsepower:
If some is good, then more is better
If more is better, then too much is just enough
Reason: wrong size fittings
