Old 02-19-2011, 07:50 PM
Gonzo24 Gonzo24 is offline
Default SD-8 aux alternator hall effect wiring?
I'm putting in a SD-8 alt and am not sure where to place the hall effect sensor for current sensing (AFS) on the output wire?
1. Should the output wire straight from the SD-8 run through the hall effect ring? the one that wires directly to the capacitor?
2. put it on the main output wire from the SD-8 system relay that ties to the electrical buss?
Seems that if it were #2 one would never be sure the SD-8 was producing power until you absolutely needed it.
Thanks for the help...
RV-7 IO-375 engine hung running the spaghetti....
Built 7A flew 700+ hrs - sold
- 7 flying
Old 02-19-2011, 09:49 PM
Walt's Avatar
Walt Walt is offline
IMO you don't need current sensing on on the SD-8, if it maintains bus voltage thats all you really need to know.
Also there won't be any current to sense unless the SD-8 is actually carrying the load.
Ammeters are "nice to know" information, bus voltage is what's really important.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 02-19-2011, 11:45 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
IIRC, the output of the SD8 is a/c, and I suspect the Hall effect sensor will not read it.
If you choose to put in the sensor, put it on the output of the "regulator".
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 02-20-2011, 11:10 AM
Default Thanks
Both good points. Thanks for taking the time to respond.
- 7 flying
Old 02-21-2011, 08:51 AM
Default shown on 'lectric Bob's Z-13 schematic
FWIW for anyone else searching this...
My above question regarding how to monitor current from the SD-8 is shown on AeroElectric schematic Z-13 "all electric airplane on a budget." The shunt is placed in the wire from the relay to the power buss.
Lesson = read all of the plans first... then post only after not finding your solution... and then only after your third or sixth beer while in the shop...
- 7 flying
