Old 02-19-2011, 04:35 PM
RidiculousM RidiculousM is offline
Default Sears Drill Press?
Any recommendations on what size? Bench or stand alone? Thanks
Old 02-19-2011, 04:46 PM
Mel's Avatar
Mel Mel is offline
If you have the space, I recommend the floor model.
Not sure about now, but many years ago when I bought mine, the Sears drill press was identical to the Harbor Freight except for a much higher price tag. I went with the HF and never regretted it. And I use it almost every day! That's been over 25 years ago.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 02-19-2011, 06:06 PM
N941WR's Avatar
N941WR N941WR is offline
Years ago I bought a 12" Delta bench top drill press. It has been just OK, nothing special.
Floor models tend to have more pulleys, thus more speeds.
Also, the Delta power switch is junk. Mine broke and wouldn't allow me to turn the thing off. This is a major safety issue, so be careful. When I called Delta about it, after checking a few woodworking boards, they said they had never heard of this problem before, yet it was a well-known issue on the other boards. Delta even made me pay for the switch, which really upset me.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 02-19-2011, 06:10 PM
jrs14855 jrs14855 is offline
Default drill press
I am very happy with my harbor freight 16 speed floor model
. I believe its the next to largest available from hf. The lower speeds are useful for hole saws and also for drilling steel with larger drill bits.
Old 02-19-2011, 06:19 PM
Mel's Avatar
Mel Mel is offline
Default Yep!
That's the one I have. Goes down to about 170 rpm.
Old 02-19-2011, 08:46 PM
randyintejas's Avatar
randyintejas randyintejas is offline
Default Drill Press
I have the Sears Bench top Drill press (multi-speed) and LOVE it. Cant go wrong with it.
RV 7
391RK Reserved
IO360 9:5:1 AFP
Slow Build
Last 90%
Tyler, Texas
Old 02-20-2011, 12:03 AM
Phil's Avatar
Phil Phil is offline
I use their floor press and it works great. Pretty easy to change the speed settings too when that's necessary.
Phil
Old 02-20-2011, 12:16 AM
Stoo Stoo is offline
I've got the Sears floor model. Found it useful a few months back as a giant arbor press to the reduce the width of roll bar during slider canopy work.
Works good as a drill press too!
Stewart
RV6, finishing.
Old 02-20-2011, 09:01 AM
Nehi Nehi is offline
Default sears drill press
I also have the sears floor model and am very happy with it but also have a HF bench model which works good, how ever a freind had a HF model that looks just like mine and had nothin but trouble, I think he's trashed it by now !
9-A slooow build- DONE & LOVIN IT !!
Nevin Miller - north Idaho
Old 02-20-2011, 09:11 AM
Av8torTom's Avatar
Default Relient
I have a Relient bench top drill press. For $129 this thing is amazing. My dad has a Sears floor model and has had nothing but trouble with it. Worst part was the spindle wasn't centered so the tip of the bit always wobbled - totally unacceptable. No issues with the Relient and I've been using if for about 10 years... oh, the plastic crank broke that adjusts the height of the table, but I fashioned a new one out of tiger maple
N677AT reserved
Superior XP O-320, 160HP
