Go Back   VAF Forums > The Never Ending Debate Section > Nosewheel vs. Tailwheel
  #21
Old 02-18-2011, 10:17 AM
Jim P's Avatar
Jim P Jim P is offline
As so many have said before, build what you want to see when you open the hangar door. You'll spend 10 hours on a tailwheel transition, if that, and you'll never have any regrets if what you want is really a t/w! These tailwheel versions really are some of the most docile you can find.
Jim
Jim Piavis
RV-7 (Flying!)
http://adap.com/rv7
Redmond, WA
Old 02-18-2011, 12:21 PM
RV7Ron's Avatar
RV7Ron RV7Ron is offline
Originally Posted by java View Post
Pick what revs your motor!
Well said, I am choosing a TD for a couple reasons: because thats what I dreamed about as a kid....purely emotional and I'm perfectly fine with that. Also, not to ruffle anyone's feathers but I think flying a TD is more of a challenge and will make me a better stick/rudder pilot.
Of course, this is all speculation at this point...I have zero hours in a TD, plan to get my endorsement this summer. At the end of the day...do what makes you happy...the rest is background noise.
Ron Duren
Mechanical Engineer
"SportAir PhD"-RV Assembly/Composites/Electrical
Denver, CO (KBJC)
RV-7 'Tip Up'
Flying!! as of 3/16/14
IO-375/WW 200G-CS/SkyView/Dual P-mags
N531R "Wablosa" Wings of Red
http://www.ronsrv7project.blogspot.com
Old 02-18-2011, 12:27 PM
turbo's Avatar
turbo turbo is offline
Talking go out........
and fly a TD. if you like it a lot go for it. get an endorsement and you are there!!!!!!!
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
Old 02-18-2011, 01:25 PM
gvouga's Avatar
gvouga gvouga is offline
Default Had a -7A now it's a -7
After flying my -7A for ~675hrs, I decided to convert it to a -7. I'm up to ~15hrs now and absolutely loving it. I should have built it this way from the beginning.
Why didn't I build a -7 from the beginning? I tried to use my engineer brain to justify all the pro's and con's. I was able to come up with more reasons to "be safe" and chose the -7A. I then talked to Van's customer support and they talked me out of converting to the -7 several times. They seem to prefer the A models (in general) over there as much as they seem to lean towards light weight VFR planes.
Bottom line: build what YOU want.
- Don't worry about experience in Tailwheels - You'll have plenty in the first couple months.
- Don't worry about insurance - it won't be much different after the first year.
- Don't worry about speed - we're talking a few kts... maybe. and that also highly depends on the build quality and equipment installed
All the other maintenance, visibility, rough runway concerns, etc. are really a toss up between the -7 and -7A. For every advantage one has, there is a disadvantage somewhere else. They are both great, safe designs that are equally easy to fly.
So what reason did I finally use to convert to the Tailwheel? "It's fun to fly and it looks really cool!"
Greg
RV-7
Old 02-18-2011, 07:15 PM
panhandler1956's Avatar
Default Looks!
As someone already mentioned, looks! Plus you won't have to give up your man-card! Just kiddin'! I like watching a can of worms too...
Brent Owens
Columbus, OH
RV-8 'Contrary Mary' flying
N784DE S/N #82614
www.fixedwingbuddha.com
Follow me on Facebook
Old 02-19-2011, 11:27 AM
mrblob's Avatar
mrblob mrblob is offline
I strongly agree with the advice to go get a tailwheel endorsement, then make your decision. I was completely hooked as soon as I started my training. Now I have a few hundred hours of tailwheel flying, and about 150 in my RV-7 with no regrets.
Paul
