Old 02-17-2011, 02:06 PM
JDanno JDanno is offline
Default Altenator charging system question!
I was flying with my friend in his C182 at night and I noticed that all the lights (instrument panel, overhead lights and appeared to be also the landing light) in the plane were flickering. The ammeter gauge also flickered in time with the lights. It appeared to be about 10 cycles per second, dim to bright-dim to bright. He said that it has always done that. At idle rpms it wasn't observed, but as the rpms increased the flickering got more pronounced.
My theory is that the alternator regulator has lost some of its diodes that smooth out the power and is causing a pronounced ripple effect in the electricity generated.
Is this any cause for concern?
Any other (better) theories??? Thanks, Dan
Old 02-17-2011, 02:12 PM
AltonD's Avatar
AltonD AltonD is offline
That sounds like a good theory. What does it do with the strobes off?
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 02-17-2011, 04:21 PM
Walt's Avatar
Walt Walt is offline
Per Zeftronics:
Flickering / oscillating ammeter and panel lights.
Check the 5 Amp breaker, ALT switch, and connections
between the bus and the input to the ACU for high resistance
or intermittent connection..
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 02-18-2011, 03:40 AM
chaskuss chaskuss is offline
Dan,
There are NO diodes in the voltage regulator. There ARE diodes [they form the rectifier] in the alternator.
Charlie Kuss
Old 02-18-2011, 05:39 AM
Default Prestolite Starter & Alternator Manuals Available On Line
Dan,
You probably don't have a Prestolite alternator. However, alternators are basically similar, so the info in the Prestolite manual is useful. You can download a copy of Prestolite's Service manual for both alternator and starter motors here. See
http://www.csobeech.com/files/Presto...atorManual.pdf
Charlie
PS I also have articles on Alternator Troubleshooting from 2 Aviation related Publications. Contact me via email and I'll send you a copy of each
Old 02-18-2011, 10:35 AM
elippse elippse is offline
It almost sounds to me as if one of the time constants in the regulator has changed causing it to go into a limit-cycle oscillation.
