Old 02-16-2011, 10:31 AM
jwilbur jwilbur is offline
Default Priming after rivets ??
Is there any reason you shouldn't put a coat of primer on an assembly after it's been riveted together? This would potentially coat rivet heads and spots of primer worn away during the assembly process.
-Joe Wilbur (N520LW)
Phase II - 11/2017
First flight - 8/2017
RV-10 Build Log
Old 02-16-2011, 10:47 AM
9GT's Avatar
9GT 9GT is offline
Thats what I do. I spray a little primer on the shop and mfg heads. It also recovers any primed spots that were scraped off during riveting.
David C.
Howell, MI
Old 02-16-2011, 11:00 AM
rleffler's Avatar
rleffler rleffler is offline
It won't cause your aircraft to fall out of the sky. It may require an extra inch of runway due to the extra weight.
I personally don't worry about it unless I really managed to scratch the previous primer coat. Most parts are going to get hit again with interior and/or exterior paint. I'm not overly concerned about the rivet heads not getting primed.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 02-16-2011, 11:25 AM
Auburntsts's Avatar
I'm with Bob on this. For the most part, I didn't go back and prime the rivets. Nothing wrong with doing it, just takes time.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 02-16-2011, 11:32 AM
I don't care to actually prime the rivet heads. I've got a few spots where the primer got really scratched up and I just want to make sure that if I DO prime over the rivet heads as I recoat the ugly spots, that this isn't going to bite me in some way in the future. I should have been clearer in my question.
Phase II - 11/2017
RV-10 Build Log
Old 02-16-2011, 11:38 AM
Auburntsts's Avatar
Nope, touch up as required. If you happen to prime some rivets in the process so be it--won't hurt a thing.
PP ASEL-IA
WAR EAGLE!
Old 02-16-2011, 01:38 PM
rapid_ascent rapid_ascent is offline
Joe,
Not that I'm an expert. Actually the more non-expert you are the more this applies I think. Anyway I started adding some tape on my bucking bar to reduce the scratching. The blue painters tape leaves blue marks so thats not too good either. Clear strapping tape seems to last OK and doesn't leave marks. Once I started adding the tape the primer damage was less. The veterans may have a better solution, but this seemed to help.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 02-16-2011, 02:52 PM
Originally Posted by rapid_ascent View Post
Joe,
... I started adding some tape on my bucking bar to reduce the scratching. ... Once I started adding the tape the primer damage was less.
Ray,
I appreciate the tip. I've actually been putting masking tape around the bucking bar AND along the flange behind/around lines of rivets and STILL I manage to scratch up the primer. Maybe I have unrealistic expectations about how pristine it should look, but when I see some of the pictures out there from the experienced builders, I'm amazed at what I see. I want my stuff looking that good, too.
Anybody out there have other tips beyond using tape and waiting for years of experience in order to avoid scratching up the primer while bucking rivets?
Phase II - 11/2017
RV-10 Build Log
Old 02-16-2011, 06:14 PM
Transporter Transporter is offline
Default Bucking "Shield"
I tape the bar with a piece of gorilla tape.
Depending on the bar, I've also used a slice (think big rubber band) from an old bicycle inner tube around the bar.
I've also used a thin piece of cardboard (old spiral notebook cover) as a "shield" to protect other parts if I'd working in an awkward spot.
Good luck,
Mike
Mike Dooley
RV hitchhiker
RV8 SB
VAF#1067, EAA Chapter 91
Old 02-17-2011, 04:52 AM
Rick6a's Avatar
Rick6a Rick6a is offline
.......tips beyond using tape and waiting for years of experience in order to avoid scratching up the primer while bucking rivets?
You do not say what type of primer you are applying but based upon my experience, it is only natural to suppose you are not using epoxy primer. Using epoxy primer, I rarely feel the need to wrap protective masking tape around a bucking bar.
If while bucking rivets you find the primer mars or scratches easily, it is not much of a leap to suppose you might be applying common rattle can, as opposed to far tougher epoxy primer. See post #13 here for my first hand observations using Akzo. The post also happens to directly address your first question about priming the shop heads of the rivets.
Note fully cured Akzo's superior touch-up qualities using an artist brush dipped in fresh primer:
http://www.vansairforce.com/communit...ad.php?t=66672
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
