Old 02-16-2011, 04:20 AM
RV6AussieNick RV6AussieNick is offline
Default The Big Cut
Hi Guys,
I'm getting close to starting the trimming and of course the Big Cut on my RV-6 that I'm rebuilding. I'm trying to read as much as I can before I get into it, I've herd about guys using Sikaflex and a primer, just not sure what sickaflex product to use. Also, what is the best type of drill bit to use to limit the possibility of cracking.
I've read a few blogs that cover there process and method of trimming and attaching the canopy, Chad Jensen has an excellent easy to follow blog http://www.chadandbrittne.com/RV-7.htm, Thanks....
Can anyone suggest other blogs that might be of help.
Nick Purcell
Licensed on B767, A330 Eng/Airframe
Fixing up RV6, building a Stewart S51
Basically a major overhaul of everything.
