Old 02-15-2011, 10:18 AM
Tram Tram is offline
Default Switch panel..
Hey guys-
Just curious if there is anyone out there who might offer a service like what I'm looking for..
Here's the deal - we didn't build our 6, so we are not stocked up on the tools of the trade, etc..
We have a switch panel that basically the builder cut one big rectangle and stacked switches into the hole. What I'd like to do is replace all these switches with something I like a little better. In order to do this without replacing the entire panel, I'm thinking about just having a small panel made to fit over the hole in the panel now and screw it, so it is removable, could rivet it, if I could borrow some tools from a local builder.
I'm wondering if there is anyone out there that could both cut the panel to my dimensions for the new switches?
Any ideas?
Thanks guys!
Jeff
Old 02-15-2011, 02:37 PM
n981ms's Avatar
n981ms n981ms is offline
I am no expert but I could do it. I assume you are cutting aluminum. I am in Dublin, Georgia if you want to travel. I am sure someone closer could help you. It could be done with any of several tools. Jigsaw, hand grinder with cutoff wheel, bandsaw, even a hack saw or dremel would do it. You would also want a file to smooth it out afterward.
Maxwell
Maxwell Duke
Kitfox S6/TD/IO240/SteamIFR Built it
RV10 IO540/AFS5600x3 Bought it
CH750 O200/AFS5500. Built it with 7 friends. DAR-Vic Syracuse
Maule M7-235C Sold it(kind of miss it)
VAF paid 5/2017
