Old 02-13-2011, 11:23 AM
larryj larryj is offline
Default Alternate Static Valve
One simple way to provide for an Alternate Static source is to run the primary static line to a pnuematic 3-port switch; have the primary port (primary switch position) feeding the instruments and the secondary port (secondary switch position) open to the cockpit. The common valves I've seen are brass, and I just didn't want the weight and look of brass; so I went looking. I found an all-aluminum-body 3-port toggle switch perfect for the above stated application and thought I'd pass it along: ARO valve #M251LS - G1130. I ordered mine from WW Grainger and their p/n is 3NB16. I received it yesterday and it is just what I was after.
Larry E. James
Bellevue, WA
Husky A1-C
Rocket (under construction)
Old 02-13-2011, 02:21 PM
SteinAir SteinAir is offline
Hi Larry,
I have one of those on my desk and while it's a fine valve, here are the reasons we decided not to stock it:
While it is aluminum, it actually weighs more than the little brass one we do stock, it's about 3 times the size (larger) and about double the price. While you'll still see a tiny little bit of brass sticking through the panel, the toggle is still chrome...a sharpie does wonders if you want to make the brass part black.
Anyway, it's not a bad valve that you have and will work fine (we've used them before) so it's not meant as a flame, just as a data point.
My 2 cents as usual.
Stein
Old 02-13-2011, 05:36 PM
Norman CYYJ Norman CYYJ is offline
Two inexpensive ways to go. Both work well, a save some money and you will probably never need it.
1- use a small tee fitting with a cap on the tee which can be taken off.
2- cut the line with a pair of side cutters. A union can always be used for repair.
Old 02-14-2011, 10:46 AM
Darn Stein, I just should have talked with you first !! And I really like Norman's idea of just cutting the line - now that is "git-er-done" !!! Thanks guys.
Larry E. James
Bellevue, WA
Husky A1-C
Old 02-14-2011, 11:07 AM
miyu1975's Avatar
miyu1975 miyu1975 is offline
just make sure you have scissors or a pocket knife, may be tough using your teeth
Ryan Allen, CFII
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 90%, fuse on order
Acro Sport 2, building
Bevan Bevan is offline
Another thing I like about the static switch, is that you can try it when ever you want (without something so drastic as cutting a line) and get a feel for the difference (error) it will cause. Adds some understanding to how sensitive the pitot static system is.
Bevan
Old 02-14-2011, 11:28 AM
kentb's Avatar
kentb kentb is offline
Default This is the way mine is setup.
The added benefit is to allow you to easily hook into the T for static check. I added the T to my pitot line also for testing.
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
Old 02-14-2011, 11:41 AM
Years ago we were taught to smash the VSI if the static line got frozen over. But that is kinda hard to do with today's glass cockpits.
Old 02-14-2011, 11:46 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Kent
Exactly! And with the QD fittings (like Stein sells, among others) you can just put a plug in it - very easy to release if required, and a service point for those two-year checks.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
