Old 02-10-2011, 04:25 PM
mfshook62 mfshook62 is offline
Default Vans R L Both Start Switch Question
My schematic shows that the R post on the R L Both start switch is connected to the right mag p-lead, and the L post is connected to the left mag p-lead. The jumper to the right p-lead is removed. I have previously tested to be sure that during a mag check when the key switch is in the R position, the right mag is enabled and the left mag is grounded to the p-lead, and vice-versa. So, Im just curious why is the R is on the left side of the key switch and the L is on the right side.
While we are on this topic, I think that the arrangement that makes most sense to me would be a key switch for: OFF L Both R with a separate start button powered from the key switch. This way its one click to the right for a right mag check, and one click to the left for a left mag check. Is the reason for the double click to R so you can compare the R to L mags with one click and to have the BOTH next to the START?
Mike Shook, RV-9A, Dynon HDX,
CPI-2 Ignition, Catto Prop, EAA 124
Old 02-10-2011, 05:49 PM
scsmith scsmith is offline
Default Not quite what you think
The switch comes with a jumper that grounds the right mag when the switch is turned to start. If you want, you can move that jumper so that the left mag is grounded when you turn to start.
But that is different from the left and right positions of the switch. When you select left, the right mag is grounded and you are running only on the left mag.
When you select right, you ground the left mag, and you are running on only the right mag.
When the switch is off, both mags are grounded.
When you select both, neither mag is grounded.
When you select start, the mag to which the jumper is wired is grounded (usually the right).
Make sense?
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 02-10-2011, 10:04 PM
ExtraKatana's Avatar
ExtraKatana ExtraKatana is offline
But why is the order of the switch (when reading from the left) R L and not L R?
Always seemed to me better labeling would be TOP BOTTOM
Old 02-11-2011, 03:11 AM
AirbusPilot AirbusPilot is offline
Originally Posted by mfshook62 View Post
My schematic shows that the R post on the R L Both start switch is connected to the right mag p-lead, and the L post is connected to the left mag p-lead. I also see a jumper to the right p-lead. I have previously checked to be sure that during a mag check when the key switch is in the R position, the right mag is enabled and the left mag is grounded to the p-lead, and vice-versa. So, Im just curious why is the R is on the left side of the key switch and the L is on the right side. I know that its been like this for a long time, but it seems to me that one click back from Both should be a right mag check and two clicks back should be a left mag check.
Mike Shook
You are right, position of left and right magnetos are reversed on the switch and I would like to know the reason too
Fernando Abasolo
Santiago Chile
SubSonex waiting for tailkit to arrive
Flying phase II RV-8 (SCSE) Serial Number 83290, Tail Number CC-AJC
Flying RV-8 (SCTB) Phase II 600 hours and counting since February 22nd 2010
Serial Number 82727, Tail Number CC-PXG
Lyc. IO-360, Hartzell Prop
VAF #2056
EAA Member 774981
Old 02-11-2011, 05:28 AM
John R. Graham John R. Graham is offline
Because of traditional mag check order, perhaps? "Left," which is traditionally checked first during run up, is closer to "Both".
- John
Old 02-11-2011, 08:50 AM
Bob Kuykendall's Avatar
Bob Kuykendall Bob Kuykendall is offline
Originally Posted by ExtraKatana View Post
...Always seemed to me better labeling would be TOP BOTTOM
That's not necessarily appropriate in a typical mag installation. In most of the installations I've seen, the left mag fires the upper plugs on one side of the engine, and the lower plugs on the other side. So there is typically not an "upper mag" and a "lower mag."
In fact, until I saw a Lightspeed ignition, I had never seen an airplane ignition where one system fired all the upper plugs, and another fired the lower plugs.
Thanks, Bob K.
Bob Kuykendall
HP-24 kit sailplane
EAA Technical Counselor
Old 02-11-2011, 09:33 AM
cfiidon's Avatar
cfiidon cfiidon is offline
Default Label top or bottom
Perhaps in the "olden days" the switches were labeled on the bottom. Then you would see
START BOTH LEFT RIGHT OFF
With the key rotated clockwise. Notice that in this case Left is on the left and right is on the right.
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
Old 02-12-2011, 04:05 PM
Av8torTom's Avatar
Default Order
The way it was explained to me, Off - Right - Left - Both, came from the days when some airplanes (e.g., early Piper Cherokees) had a separate button start switch, and those engines were started off the left mag. Once the engine started it was one click clockwise to get to Both without having to go through Right - *shrugs*
N677AT reserved
Superior XP O-320, 160HP
