Old 02-08-2011, 07:14 PM
N601RX N601RX is offline
Default Ney Nozzles
Does anyone have any experience with the Ney nozzles in in IO 360 or other engine?
Mike
Old 02-09-2011, 11:47 AM
avq avq is offline
I had Chuck Ney install them in the O-320 I am currently rebuilding. To be honest I am not sure how much they will help. I've have cam rust issues before so I figure I will add a pre-oiler to the engine to oil the cam and followers prior to start and weekends that I do not fly.
Anton Quiroz
RV-7 Empennage complete, working on wings
Old 02-09-2011, 12:17 PM
rocketbob's Avatar
I had Chuck put them in the case on a 540 I overhauled. They're just squirters from the main galleys that point at the cam lobes. I'm sure they help but to get the real answer on what they do one has to gauge cam/tappet wear at overhaul.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 02-09-2011, 02:33 PM
GEM930 GEM930 is offline
I have them installed in my 320 h2ad. I bought the plane flying and thought they were a solution to the cam troubled h2ad. Is that the case? I have noticed if the oil is hotter then normal and the plant is at idle the oil pressure is sometimes just under 20psi. That kinda freaks me out a little. Dont know if that is a result if the installation or not?
Old 02-09-2011, 09:23 PM
avq avq is offline
We also installed the nozzles on the o-320 in my cherokee and I did not see any low pressure issues after install.
I would investigate that asap. Low oil pressure can be a sign of trouble.
Anton Quiroz
