Old 07-11-2014, 07:05 AM
Brantel's Avatar
Brantel Brantel is offline
Follow up...this weekend I replaced the tiny Firgelli servo with a standard Ray Allen T2-7A.
Early in test I had noticed some freeplay developing within the Firgelli servo and expected it to strip a gear due to heat, which measured at about 160F in the servo location. However, it has been hanging in there since Christmas, so bravo to the designers.
That said, OSH is coming and I didn't want to chance a failed air door inbound from Ripon. The RAC servo is larger and more powerful, meaning the load applied in this app should only be a small fraction of normal capacity, i.e. low load on the gears when hot.
Dan,
Since Allan has brought an OTS solution to market using a similar actuator, did you ever tear that thing apart to see if it was a pending failure or?
As far as the RA T2-7A. How is that servo holding up?
By the way, thanks to Lars, I now have everything I need to make the piccolo tubes and gather some real data to answer your question in my other thread....
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 07-11-2014, 09:35 AM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
About 11.2; the EGT values are degrees ROP.
Dan, a question that is a little bit off the current topic but still of interest concerning the shrinking exit -- Have you evaluated the CHT's, TAS, fuel flow, Oil Temp, etc. while running in the same configuration as you posted in #190 while LOP? If so, what numbers have you seen LOP in that similar environment?
RVBYSDI
Steve
RV9A
https://rvwings.com
Live Long And Prosper! 🖖🏻
Old 07-11-2014, 01:24 PM
DanH's Avatar
DanH DanH is offline
Not seriously. No point. The benefits/shortcomings of LOP operation are independent of exit area.
Dan Horton
RV-8 SS
Barrett IO-390
Old 07-11-2014, 01:55 PM
RVbySDI's Avatar
Understand about the exit area issues not really relevant for a conversation on LOP operations. I was just curious if you tested running LOP compared to ROP and what the delta was for the parameters mentioned.
Hope to talk with you again at OSH.
RVBYSDI
Steve
RV9A
https://rvwings.com
Old 01-01-2016, 12:34 PM
AX-O's Avatar
AX-O AX-O is offline
Dan, i am designing a cowl flap for summer ops. How is the RA servo holding up?
I am going to finish my flight test phase before starting all the press/temp measurements under the cowl. I have all the instrumentation ready. I wont make any FWF mods until I am instrumented.
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
The information that I post is just that; information and my own personal experiences. You need to weigh out the pros and cons and make up your own mind/decisions. The pictures posted may not show the final stage or configuration. Build at your own risk. Further more, these are my opinions and not those of my employer.
Old 01-01-2016, 07:50 PM
DanH's Avatar
Originally Posted by AX-O View Post
Dan, i am designing a cowl flap for summer ops. How is the RA servo holding up?.
Doing fine. Arrange the door linkage to minimize gear load.
Dan Horton
RV-8 SS
Barrett IO-390
Old 02-26-2016, 01:43 PM
DanH's Avatar
Follow up report.
Started flying this oil cooler air supply duct in early 2013. The goal was to reduce the temperature of the air reaching the ducted oil cooler; measurements said the air picked up as much as 17F as it made its way from the cowl inlet to the rear baffle wall.
The duct dropped average oil termperature as expected, but I later decided to install a larger 10611 oil cooler anyway. I removed the above duct from the plenum lid at the most recent annual. As an experiment, it proved the theory, but isn't really needed now.
The 10611 with inlet and outlet ducting remains. Inlet is fed from the rear baffle wall. Cooler hangs on the motor mount. Inlet diffuser has a turning vane. The outlet duct sits flat against the firewall and terminates in the top of the cowl exit bell.
Dan Horton
RV-8 SS
Barrett IO-390
Old 06-01-2017, 08:36 AM
DanH's Avatar
I happened to be looking up some old data from past tests, and just out of curiosity, ran the numbers for coefficient of pressure as defined in NASA CR3405, to wit:
(plenum static pressure less freestream static) / freestream dynamic pressure
The three measurements made in level flight were done at partial power, in each case just enough to maintain the desired 120, 140, and 160 IAS. The resulting true airspeed (NTPS method) is shown here. A Cp in the high 0.8 range is very good.
The curiosity point was the effect of propeller outflow at full power and 100 IAS, given a constant speed BA Hartzell, with low Vi/Vo inlets moved outboard as far as possible, and in close proximity to the blade. Cp turned out to be 1.17 when calculated using 100 knots for the dynamic pressure. The difference between Cp in the 0.8's and 1.17 is almost entirely due to high velocity air from the prop, meaning prop outflow is a very large part of cooling power in a steep climb.
There is a probable prop outflow contribution in the level flight values too, but not nearly so much, as the power settings were quite low, and the difference between prop outflow and aircraft TAS gets smaller as velocity goes up. It might be interesting to get some pressure numbers with the prop stopped, for comparison.
Note, these measurements were taken several exit iterations in the past....a small fixed exit ending at the plane of the firewall, the smallest in the very first post.
Dan Horton
RV-8 SS
Barrett IO-390
Old 06-02-2017, 06:04 AM
ronschreck's Avatar
ronschreck ronschreck is offline
Default Let's look at it another way...
Dan,
I appreciate the effort you have contributed to this project. I'm no engineer and I find it difficult to follow your logic so I looked up a video which explains it in terms that I can understand. Maybe this will help others as well.
https://www.youtube.com/watch?v=RXJKdh1KZ0w
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours- Sold
My Aerobatic Video
My Formation Video
CAF B-25 - Airbase Arizona
VAF 2022 Donor
Old 06-02-2017, 08:03 AM
ackselle's Avatar
ackselle ackselle is offline
Thanks Ron,
Like you, I had a tough time following Dan's logic...but your post very much helped me get my head around some of the technical issues. The explanation of the Rockwell Retro Encabulator put everything into easy perspective.
Ackselle
ackselle
CJB3 (Steinbach, MB Canada)
Van's RV-7A (C-FIJT)
You can do anything!...but you can't do everything.
