Old 04-04-2006, 04:28 PM
339A's Avatar
339A 339A is offline
Default Sean Tucker Bails
Just recevied this from a friend of mine.
http://www.aero-news.net/
Looks like he had a control stick issue, took so time to figure it out after takeoff and then bailed out over an empty field. I was looking foward to watching his routine this week at Sun N Fun.
Scott Mills
N339A
Old 04-04-2006, 06:03 PM
arffguy arffguy is offline
Default Just lost the airplane, Thank God.
****, what a shame. Thank God he survived such a failure. Sean and Wayne Handley (Raven) is/was the most interesting airshow pilots to watch in my opinion. (Whooeee!) Those two got together and invented some really wild maneuvers. I hope to see Sean in a new airplane soon. Wayne, unfortunately for airshow fans, is retired from airshow flying but still flies an Extra 300L, provides aerobatic instruction and does seminars.
Mike F
RV-6A wings/fuselage
RV-3 empennage (extra thanks to Mr. Zilik)
RV-4 Plans only S/N 2938
Cessna 152
Elk Grove, CA
VAF #744 Exempt but paid anyway
Old 04-04-2006, 06:09 PM
cjensen's Avatar
cjensen cjensen is offline
yeah, this is really a shame, but i'm very happy he's is fine. he is probably the best i've seen (jim leroy being a close second). they can build a new airplane...
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
Old 04-04-2006, 06:24 PM
airtime's Avatar
airtime airtime is offline
Default **** tail
When I first saw this thread I had one question - "did he hit the tail again".
The news release answered that question. "despite getting temporarily hung up on the tail"
This is not the first time Sean has encountered the tail on exit, something we have in common.
Rob H
Old 04-04-2006, 06:28 PM
RV7Factory's Avatar
RV7Factory RV7Factory is offline
Chief Obfuscation Officer
What a shame, but glad he is OK.
I trained at Sean's school a few years ago. It was during the off season and it was amazing to see the plane get completely rebuilt over the course of two months. It is truly an amazing aircraft. They fill the fuselage with nitrogen and Sean has a small pressure gauge in the cockpit. Any decrease in pressure means a tube/weld is cracked somewhere and its time to stop flying.
There is an in-cockpit video somewhere of Sean keeping his cool as the prop flys off a Pitts he is flying (IIRC, giving a ride to a reporter). You see the prop fly by in a puff of smoke and the passenger starts freaking out. He remained calm and put it on the ground safely.
Brad Oliver
Livermore, CA | RV-7 | SOLD
RV-7: RV7Factory.com | iPhone app list: AviatorApps.com | Photography: BradOliver.com
Old 04-05-2006, 08:17 AM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Default Try it at HOME
Go up to a safe altitude and with out using any pitch input, just rudder, aileron and elevator trim, try to fly your plane, NO REALLY! I wounder how it would work. I think its doable, however landing? Doubt it. Obviously that was Sean's idea. Does this mean a parachute can save your life? Yea sure that is why I wear one. Here is a more direct link:
Sean Bails from the Oracle
Also in aero-news a LSA goes down with an aviation writer due to LOW POWER from the little ROTAX. Don't let people tell you that high performance aircraft are more dangerous. Obviously the engine was not at 100% power for some reason, but when you are Rocking only minimal power you can't afford to loose any:
Light Sport Airplanes have low HP by design and Regulation. Is that good?
George
Old 04-05-2006, 08:31 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Default Low power
Originally Posted by gmcjetpilot
...Also in aero-news a LSA goes down with an aviation writer due to LOW POWER from the little ROTAX. Don't let people tell you that high performance aircraft are more dangerous. Obviously the engine was not at 100% power for some reason, but when you are Rocking only minimal power you can't afford to loose any:
When I fly an aircraft with a fixed pitch prop, my first check after applying power on the takeoff roll is to ensure I have the expected RPM. If not, I chop power and stay on the ground. From what this article said, this guy didn't do that. I think a similar problem could happen with any engine on any aircraft. I was happy to read that it seems his prognosis is good.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 04-05-2006, 08:44 AM
339A's Avatar
Here is a link to the local news story about the crash.
http://www.ktbs.com/news/local/25748...?video=YHI&t=a
The plane is completely destroyed. Won't be flying that plane anytime soon.
Scott
Old 04-05-2006, 09:17 AM
cjensen's Avatar
wow. good link, and the media wasn't too bad on that report!
Chad Jensen
Old 04-05-2006, 10:56 AM
keen9a's Avatar
keen9a keen9a is offline
Default Oracle Challenger Memories
These are all from Oshkosh 2003-2005 (click for full size). Sure glad Sean is OK.
UPDATE: Fixed Links (I hope!)
Ben Keen
RV-9 Flying 8/21/2016
http://www.pbase.com/benkeen/rv9
