Problem: Butchered HS front spar/nose/main rib/spacer rivet holes when I took everything apart to do it right. All other holes good and with patience and care everything else went back together great, drawing heavily from tips in these forums (thanks!).
Question is, can I just drill another #30 hole between the present rivets, deburr with a Burraway, and install another 470-4 rivet, or do I need to remove and redrill for the next size up. I assume I can get 470-5 rivets? Anything else I should consider?
Advice appreciated...
http://img146.imageshack.us/img146/6...etoobig7zy.jpg
