View Poll Results: What brake fluid are you using and what would you use next time?
Currently using MIL-H5606 66 40.24%
Currently using MIL-83282 39 23.78%
Currently using Mobil 1 ATF 36 21.95%
Currently using DOT "X" (some form of DOT) 9 5.49%
Currently using none of the above 4 2.44%
Next time will use MIL-H5606 26 15.85%
Next time will use MIL-H83282 15 9.15%
Next time will use Mobil 1 ATF 21 12.80%
Next time will use DOT "X" (some form of DOT) 6 3.66%
Next time will use none of the above 2 1.22%
Multiple Choice Poll. Voters: 164. You may not vote on this poll
Old 02-04-2011, 01:15 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Default Brake Fluid Poll
There have recently been a couple extensive threads about brake fluid choices. What's everyone currently using and what would you use if you did it again?
Old 02-05-2011, 10:34 AM
Just bumping to try to get some more results
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 02-05-2011, 11:49 AM
Guy Prevost's Avatar
Guy Prevost Guy Prevost is offline
I'm firmly in the Mobil 1 ATF camp. It's available everywhere and has worked well for me.
Guy Prevost
Albuquerque, NM
RV-8a Built, Enjoyed, Sold
Two Kids: Built, Enjoying
RV-10, Bought, Rebuilt, Enjoying
Build / First Flight Video: http://www.youtube.com/watch?v=8f9HXzZT1dE
Build Log: http://websites.expercraft.com/geprevo/
Arguing on the internet is like having a competition to see who can hit a brick wall the hardest. You may win, but you're still an idiot.
Old 02-05-2011, 04:52 PM
breister breister is offline
Have a gallon jug of 5606, also use it for my hydraulics so it is convenient to stick to a single fluid. Matco masters, slaves, and brakes. Works without complaint.
Old 02-06-2011, 09:01 AM
Pat Hatch's Avatar
Pat Hatch Pat Hatch is offline
Default MIL-83282
I used to use 5606 but became a convert to 83282 after reading about brake fires plaguing some, mostly glass, airplanes, but I think it could happen in an RV as well. We had a Cirrus burn to the ground here on our airport some time back. He was testing his brakes, caught them on fire (5606) and by the time the fire department got to him his wing and fuel had caught fire.
I think 83282 has mostly replaced 5606 in military and commercial aviation as well. Not to say 5606 is bad, just that 83282 is better.
I also flush and replace brake fluid at every other annual condition inspection. Back in my 5606 days, I had pulled one of my master cylinders to fix a small leak and was amazed at how cruddy looking the residual fluid was that spilled out of the actuator!
Pat Hatch
RV-4 (Gone to RV heaven)
RV-6 (N44PH - Flying)
RV-7 (Sold)
RV-8 (Builder & Avionics Installer)
www.phaviation.com Trim Relay Boards/Flap Actuators
www.pathatch.com/blog (Photography)
Track Me
Old 02-06-2011, 11:07 AM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
I'm still using 5606, but on the list of things to change. I added passenger-side brakes to my -6 about 5 years after it was first filled with 5606 and upon disassembly, I noticed that the fluid in the white plastic supply lines had turned into a thick, sticky goo. After seeing that, I flushed the entire system and found the fluid in the whole system had thickened as well. And the whole time before I added the passenger-side brakes, the braking system always operated well, with the brakes releasing and engaging normally.
Now, the question is, is Mobil1 ATF compatible with residual 5606 in the system, or do I need to do a proper flush and replacement of O-rings?
Old 02-08-2011, 03:42 PM
Yeah, I'm not surprised that people are using 5606, but I am surprised that more of them don't plan to go up to 83282 (or something with a higher flashpoint) next time given that it seems to be readily available and not significantly more expensive.
Steve M.
Ellensburg WA
Old 05-07-2014, 05:18 PM
Jim Wright Jim Wright is offline
Default Brake fluid
The best is Royco 782, comes in quart cans.
It is compatible with 5606 so you can drain your system and service it with Royco 782.
Old 05-07-2014, 05:53 PM
TomVal's Avatar
TomVal TomVal is offline
That's what I just serviced my brake system with.
Tom Valenzia
RV8 (Sold)
RV12 Jabiru 2200 Powered (Sold)
Dues contributor since 2007
Learn from the mistakes of others. You won't live long enough to make all of them yourself...Anonymous
Old 05-07-2014, 06:15 PM
skylor's Avatar
skylor skylor is offline
Default Royco 782 = MIL-83282
Royco 782 IS MIL-83282
Skylor
