Old 02-03-2011, 06:53 PM
CPSONE's Avatar
CPSONE CPSONE is offline
Default VS Rear Spar doubler for -7
I bought a rather untouched used -7 emp kit. The previous builder had gone ahead and cut the lightening holes in the VS rear spar doubler. I thought I'd be smart and order up a replacement from Van's so I could install one without the lightening holes for greater strength, minimal as it may be.
I just received my order from Van's and to my surprise the lightening holes are already factory cut in the VS rear spar doubler. No a big deal really but it put a kink in my plan. So much for the "optional" part as it says on the plans...
Mike
RV-6 emp, done-sold,
RV7A QB. Passed pre-cover and sold!
Disclaimer: Everything I say can be presumed to be wrong. Don't try this at home.
Old 02-03-2011, 07:30 PM
N941WR's Avatar
N941WR N941WR is offline
The -7 and -9 share the same VS, and back when I was building my VS, I called Van's and asked them if I should cut those holes or not. The answer I received was that those holes don't impact the strength significantly and to "Build lightness in". After hearing that, I took every lightening step recommended in the plans.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 02-04-2011, 01:34 AM
kiwipete kiwipete is offline
Default Weight savings
Another bonus of lightning the rear of the plane is it will also help c of g. Only slightly but might allow another pound or two baggage if you have a lighter engine prop combination.
Peter
RV7 G-PBEC Flying
RV10 Finishing
