02-03-2011, 03:26 PM
Inline fuel filter cleaning
I plan to have a fuel filter in each wing root. I have seen really neat installations of inline fuel filter or even gascolators in wing roots on this forum.
I probably go with the inline fuel filter, because of the following reasons:
- space is marginal (RV-4 has a smaller gap between fuselage and wing than the other RV's)
- plane is aerobatic, i.e. if I don't drain the gascolator before each aerobatic flight I will get the water in my engine. So I will have to drain 4 locations (2 tanks, 2 gascolators)
Now my question: How do you maintain and clean your inline fuel filters (no matter if it's in the wing root or somewhere else)? I don't feel comfortable to remove the hard fuel line too many times without damaging it. Could a flexible fuel line be a solution?
Thanks for your inputs.
Andreas Uebersax
RV-4 SN2416 in slow progress
Switzerland
VAF donation 2019/12/13
02-03-2011, 05:55 PM
Just remember that with this setup you'll have to drain your fuel tank to change the filter. The standard location for the filter being downstream from the fuel shutoff valve has advantages. -Jim
02-04-2011, 10:51 AM
Fuel Line
I used a flex fuel line on my in line filter and it has worked great. I changed it out last year after 4 years because it had some surface cracks on it. The standard replacement time is five years on repacing flex lines and mine could probably have gone another year.
Kurt Lohmueller A&P, DAR
Powder Springs, Ga
RV6A "Kurt's Toy" - Flying
RV12 - Flying - Sold
02-04-2011, 11:11 AM
My filters are upstream of the valve. I installed a small "ball" valve upstream of each filter for servicing.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
02-25-2011, 06:31 PM
Another option
Another option is to have an AN806-06D fitting on hand, when you service "wing root" fuel filters. These will allow you to simply plug the line coming from your fuel tank, during servicing. A small amount of fuel will be lost,while you install and remove the plug. See
http://www.aircraftspruce.com/catalo...s/an806-2d.php
Charlie
08-05-2012, 08:32 PM
Need your advice Mel
Pretty much copying your fuel system Mel and wondered what kind of ball valves you used. NPT thread? What type of seal (Teflon)?. I can get my hands on all kinds of valves since I'm a pipe fitter but thought maybe you found something special that would adapt better to the tight location and avgas.
Tom
Tom Norwood
Classic "Short Tail 6A N822PM
TMX-O360. Phase 1
08-05-2012, 09:24 PM
Valve
Sam Evans
RV7-A O-360 C/S
VAF#812
08-06-2012, 11:02 AM
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
08-06-2012, 02:19 PM
I like that one!
Originally Posted by Bevan
That's the best one I have seen Bevan. Small, lightweight, and made for fuel.
Perfect!
Tom
Tom Norwood
TMX-O360. Phase 1
